I am currently taking my first steps with ControllerX and I am trying to get my Hue Dimmer Switch (RWL021) up and running with the ZHA integration. But just the standard operations (on, dim up, dim down, off, color wheel) do work but my automations do not. The mappings do not seem to be correct.
In the developer tools, I am able see all possible button events such as
(please click to open)
"event_type": "zha_event",
"data": {
"device_ieee": "00:17:88:01:04:e4:8e:6c",
"unique_id": "00:17:88:01:04:e4:8e:6c:2:0xfc00",
"device_id": "b33f605d530e2dbe443a69a2c3f43362",
"endpoint_id": 2,
"cluster_id": 64512,
"command": "up_press",
"args": {
"button": "up",
"press_type": "press",
"command_id": 0,
"args": [
2,
3145728,
0,
33,
0,
0
"origin": "LOCAL",
"time_fired": "2022-01-15T21:07:48.154548+00:00",
"context": {
"id": "6e22c32c817ec237c3037c2029b62def",
"parent_id": null,
"user_id": null
The corresponding light goes on and off and dims as requested but my automations do not work:
hue_dimmer_ceiling:
module: controllerx
class: HueDimmerController
controller: '<my_ieee_id>'
integration: zha
light: light.mylight
merge_mapping:
1000: # On short released
- service: script.hue_set_scene
scene: 'Bright'
1001: # On long released
# similar script call ...
2001: # Dim up long released
3001: # Dim down long released
4000: # Off short released
Please note that the script script.hue_set_scene
does work in another context. After studying lots of threads I assume that it may have something to do with wrong mappings (“1000”, “1001”, etc.) but I was not able to find a clear documentation for the use of HueDimmerController with the ZHA integration.
So my question is: What are the correct mappings for a Hue Dimmer Switch (RWL021) in a ZHA context?
Many thanks in advance!
