YUHAO 52 inch Black Ceiling Fan with Lights and Remote Control,Dimmable tri-Color temperatures LED,Quiet Reversible Motor,5 Blades Modern Ceiling Fans for Indoor. https://a.co/d/2c4wgwE
It uses a 2.4 Ghz RF remote that operates between 2415 Mhz and 2475 Mhz on channel F. Here is the FCC patent info on the remote:
I’d like to copy the RF commands that the remote sends to the fan and then repeat them using some sort of hardware that can integrate with Home Assistant, but I haven’t found anything. I know Broadlink doesn’t work, but I can’t find any other off-the-shelf solution.
Has anyone managed to solve this issue or have any ideas on what I can do that doesn’t involve soldering or removing the fan from the ceiling?
Were you able to find a solution for this? I have 3 of these fans and 2 other which are all 2.4 Ghz RF remote controlled DC Fans that I am struggling with.
Unfortunately, no. I tried capturing the 2.4 Ghz RF signals using RFLink, an Arduino, and an NRF24L01 transceiver but it didn’t pick anything up, so now I’m back to square one with this.
Nope! I have two of these fans and their remotes do not work on the other fan at all. The owner says they’re individually programmed, and honestly I’m not sure what happens if I lose my remote. I think there’s a way to program a “fresh” remote to a fan, but I don’t know how or what the process would be.
