Integrating my boiler system into HA. Got most everything working, i.e. boiler lockout over 60 degrees F, single device zones working properly. ESPhome based. Master bedroom has 2 zone valves that I’m trying to put onto 2 separate relays as follows:
- platform: generic_thermostat
heater: switch.relay_channel_1
heater: switch.relay_channel_2
target_sensor: sensor.lumi_lumi_weather_28344b04_temperature
min_temp: 62
max_temp: 75
Works, but only brings on switch.relay_channel_2, not both. If I remove the switch.relay_channel_2, it will bring on switch.relay_channel_1. Does generic thermostat only allow for one device to be controlled?
