Core updates happen in my installation of HA. Please let me know to install software to control the fan speed?
An alternative approach (which I find cleaner and also dynamically adjusts the fan), is to set an automation to adjust the fan speed every X seconds and calculate the relative fan speed based on a temperature range. For my use, I want the fan to spin at a minimum of 65% (which seems to be my fans minimum - NASPI), if the temperature goes over 40c (I’m in the UK and the pi stays below 40 usually), dynamically ramp the temps up to 100 at a max temp of 70 and scale down under this temp…
service: light.turn_on
brightness_pct: >
{% set cpu_temp = states('sensor.processor_temperature')|float %} {% if
cpu_temp <= 40 %}
65
{% elif cpu_temp > 50 %}
100
{{ ((cpu_temp - 40) * (100 - 65) / (50 - 40) + 65)|round(0) }}
entity_id: light.rpi_cooling_fan
Hope this helps someone.
Hi every one,
I try to install and use rpi_gpio_pwm on my home assistant wich is on a raspberry Pi 4 on a container.
This what I see on logs
Logger: homeassistant.components.light
Source: custom_components/rpi_gpio_pwm/light.py:71
Integration: Lumière (documentation, issues)
First occurred: 14:54:12 (1 occurrences)
Last logged: 14:54:12
Error while setting up rpi_gpio_pwm platform for light
File "/usr/local/lib/python3.10/site-packages/gpiozero/pins/data.py", line 1194, in from_revision
) = PI_REVISIONS[revision]
KeyError: 1684095520
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 304, in _async_setup_platform
await asyncio.shield(task)
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/rpi_gpio_pwm/light.py", line 71, in setup_platform
led = PwmSimpleLed(PWMLED(pin, **opt_args), led_conf[CONF_NAME])
File "/usr/local/lib/python3.10/site-packages/gpiozero/devices.py", line 108, in __call__
self = super(GPIOMeta, cls).__call__(*args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/gpiozero/output_devices.py", line 403, in __init__
super(PWMOutputDevice, self).__init__(
File "/usr/local/lib/python3.10/site-packages/gpiozero/output_devices.py", line 83, in __init__
super(OutputDevice, self).__init__(pin, pin_factory=pin_factory)
File "/usr/local/lib/python3.10/site-packages/gpiozero/mixins.py", line 85, in __init__
super(SourceMixin, self).__init__(*args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/gpiozero/devices.py", line 548, in __init__
self.pin_factory.reserve_pins(self, pin)
File "/usr/local/lib/python3.10/site-packages/gpiozero/pins/pi.py", line 91, in reserve_pins
super(PiFactory, self).reserve_pins(
File "/usr/local/lib/python3.10/site-packages/gpiozero/pins/pi.py", line 92, in <genexpr>
requester, *(self.pi_info.to_gpio(pin) for pin in pins))
File "/usr/local/lib/python3.10/site-packages/gpiozero/pins/__init__.py", line 169, in <lambda>
lambda self: self._get_pi_info(),
File "/usr/local/lib/python3.10/site-packages/gpiozero/pins/pi.py", line 116, in _get_pi_info
self._info = PiBoardInfo.from_revision(self._get_revision())
File "/usr/local/lib/python3.10/site-packages/gpiozero/pins/data.py", line 1198, in from_revision
raise PinUnknownPi('unknown old-style revision "%x"' % revision)
gpiozero.exc.PinUnknownPi: unknown old-style revision "64614220"
Some help please ?
Hello, total noob here - this page has really helped me in getting my PWM cooling fan functional on my HA RPi 4. I managed to follow the instructions including the automations and it seems to be holding my CPU temp steady at ~43C! For reference if anyone’s setting it up for the first time I have:
-Noctua NF-F12 PMW 5V 120mm fan
-3d-printed Raspberry Pi Case with FULL 120mm FAN (Raspberry Pi 4 Case with FULL 120MM FAN by jesperklang - Thingiverse)
-fan pins plugged into GPIO pins 4(5v) / 5(GND) / 10(GPIO18) (for hardware PWM)
I set the PWM frequency to 25000 based on Noctua’s documentation for the fan. It starts up at 10% and runs totally silent. I have it set to ramp up above 40C but run constantly at 15% below.
I ran into an issue with the configuration.yaml formatting. The #RPI fan control needs to go under command_line as seen here:
light:
- platform: rpi_gpio_pwm
leds:
- name: RPI Cooling Fan
frequency: 25000
pin: 18
command_line:
# RPi fan control
# - platform: command_line (original text)
name: CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) | round(1) }}'
scan_interval: 10
Hope this is helpful for someone, y’all have helped me immensely and I look forward to future projects.
also for me this thread was very helpful sorting my fan control. Thanks to all who contributed.
As my setup is working now I wanted to share my settings.
RPI 4B 8GB with SSD in an Geekworm NASPI 2.0 case.
HA 2023.10.0 Home Assistant Operating System.
To get the fan running I followed these steps:
- Install PIGPIO and Pi GPIO PWM as described above.
- in configuration.yaml:
command_line:
# NASPI fan control
scan_interval: 10
light:
leds:
pin: 18
frequency: 25000
- in automations.yaml
- id: '1112223334445'
alias: CPU_Fan_Control
description: CPU_Fan_Control
- platform: state
entity_id:
- sensor.cpu_temperature
condition: []
- service: light.turn_on
brightness: "{% set cpu_temp = states('sensor.cpu_temperature')|float %}
{% if cpu_temp < 40 %} 130 {% elif cpu_temp > 45 %} 220 {% else %} 150
{% endif %}"
That’s it.
My CPU fan is running now on a minimal speed to have some airflow in the case. When CPU temperature increases due to load or external conditions the fan runs faster to get back to the normal temperature window.
HACS isn’t supported for HA on a container.
@von-zinzer
GPIO18 is on pin 12 and not 10, which is GPIO 15
As @gorbirad wrote:
I would also like to know how I can measure the speed of the fan.
Why can’t I find the RPI GPIO PWM add-on in HACS? I can only find “Raspberry Pi GPIO” and “Raspberry Pi RF.” It seems like I’m the only one with this issue and I feel like I’m losing my mind. Searching “pwm” only returns “No repositories matching search.”
Not just you, it seems to have been removed judging by other posts like this one. No idea why it was removed, but I imagine you could still install it manually.
Using this post as a guide I made a dumber version if it (it simply turns the fan on and off, no support for different speeds). I’m no HA expert but if you want something similar, here’s what I did:
- Install pigpio add-on as described
- Skip installing the GPIO PWM add on and install “Raspberry Pi GPIO” from HACS instead
- Add the following to your
configuration.yaml
# CPU Temp sensor works fine as is
command_line:
- sensor:
value_template: "{{ value | multiply(0.001) | round(1) }}"
scan_interval: 10
# add rpi_gpio switch for fan, be sure to check the GPIO pin number
switch:
switches:
- port: 14
- Add simple automation to control the fan switch based on fan sensor (I did this in the UI, but here’s the resulting YAML)
- id: '1699310657518'
alias: CPU Fan Control
description: ''
- platform: state
entity_id:
- condition: numeric_state
entity_id: sensor.cpu_temperature
above: 45
- service: switch.turn_on
data: {}
entity_id: switch.cpu_fan
- wait_for_trigger:
- platform: numeric_state
entity_id:
for:
hours: 0
minutes: 1
seconds: 0
below: 37
- service: switch.turn_off
data: {}
I’m sure there are better ways to do this, like I imagine you use some command line to set the fan speed with pigpio, but it is working well enough for now.
Thanks for this- I installed Raspberry PI GPIO from HACS (no pigpio needed)
I copied the configuration.yaml as above and (instead of the automation) I configured a generic thermostat to pick up the sensor.cpu_temperature and switch.cpu_fan and it seems to do the trick. It is still on/off control, but a bit handier
Thanks for posting the correct code for the CPU, other guides have the code below which does not work, very frustrating!
Now I have GPIO control and CPU temp working, I have realised my fan is 2 cable, rather than 3. There is no way to control a 2 cable fan right?
command: “cat /sys/class/thermal/thermal_zone0/temp”
unit_of_measurement: “°C”
value_template: “{{ value | multiply(0.001) | round(1) }}”
scan_interval: 10
Not an expert but I believe you are correct - two pins would just be power (constant voltage) and ground, the third pin is required for control.
Hi there!
Thanks for sharing your steps which i followed until part 3. Unfortunately, i am still not able to switch on/off the fan with the button (switch) that i have added on my overview page. I m missing something i guess but can’t figure it out.
I am using a RPI4, fan is 3 wires, red wire connected to pin 4 and black to pin 6 and yellow connected to gpio 14 (pin 8). I have installed both add-ons (pigpio and Raspberry Pi GPIO).
My config file is as below:
command_line:
- sensor:
name: RPI CPU Temperature
scan_interval: 10
switch:
switches:
- port: 14
unique_id: "rpi_cooling_fan"
The fan won’t stop even if i have switch if off with the button that i have added
I am now thinking about a permission issue with gpio pins… anyone has an idea?
Thx for any help!
Hi there, just a question, how do you run your HA? on a RPI? which kind of installation ? HAos? thx
RPi 4 with external SSD and plain vanilla HAos
Hello
I followed the steps but now I get the following error code.
Source: helpers/entity_platform.py:361
Integration: Licht (documentation, issues)
First occurred: 21:10:09 (1 occurrences)
Last logged: 21:10:09
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 361, in _async_setup_platform
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/rpi_gpio_pwm/light.py", line 70, in setup_platform
opt_args["pin_factory"] = PiGPIOFactory(host=led_conf[CONF_HOST], port= led_conf[CONF_PORT])
File "/usr/local/lib/python3.11/site-packages/gpiozero/pins/pigpio.py", line 101, in __init__
raise IOError('failed to connect to %s:%s' % (host, port))
OSError: failed to connect to localhost:8888
Can someone help me with this?
My fan control suddenly stopped working. Two things helped me:
- Changed the entity_id in all automations from
to
entity_id: sensor.processor_temperature
- Added a unique Id for the “RPI Cooling Fan” in the configuration.yaml:
light:
leds:
pin: xy
unique_id: whateveridyouwant
Hope that helps one or the other.
Best
Hi, I solved the error
of the rpi_gpio_pwm add-on, simply by installing the Poeschl pigpio add-on (as written in the rpi_gpio_pwm readme) and then restarting HA.
Installing pigpio is done by adding https://github.com/Poeschl/Hassio-Addons
into your HA add-ons custom repositories.
I hope it can be useful to someone.
I would like to use your automation. How do I use your code to create one? I tried copy and paste but get an error “Message malformed: extra keys not allowed @ data[‘service’]”
did you ever find the answer?
Just in case anyone wants it, I made a better python script that has a threshold limit and better status returning:
try:
fan_speed = data.get("fan_speed")
threshold = 25
above_th = fan_speed > threshold
set_speed = (fan_speed if above_th else threshold+1)
service_data = {"entity_id": "fan.rpi_cooling_fan", "percentage": set_speed}
if (fan_speed >= 0 and fan_speed <= 100):
if fan_speed == 0:
service_data = {"entity_id": "fan.rpi_cooling_fan"}
hass.services.call("fan", "turn_off", service_data)
output["result"] = {"level":"success", "message":f"CPU fan off"}
else:
hass.services.call("fan", "turn_on", service_data)
if above_th:
output["result"] = {"level":"success", "message":f"CPU fan set to {set_speed}%"}
else:
output["result"] = {"level":"warn", "message":f"{fan_speed}% is too low, CPU fan set to {set_speed}%"}
else:
output["result"] = {"level":"error", "message":f"Got invalid value, fan_speed: {fan_speed}"}
except Exception as e:
output["result"] = {"level":"error", "message":f"Unknown error: {e}"}
The reason I did this is because I’m using a non-PWM fan, and I built a 0-5v DC control circuit that converts PWM voltage into 0-5v DC to run the fan. Setting the percentage too low causes my fan to make noise and not spin, and having no control ciruit causes the PWM noise to be very audible <100%
What I used:
https://forums.raspberrypi.com/viewtopic.php?t=305481
