Controlling blinds?
I would like to make my window blinds remote-controllable. The easiest solution would be to install some Zigbee-module behind the switches.
But which one should I use?
I tried the “Moes Smart Curtain Switch Module”.
But it has some built-in timer: If I let the blinds move down for e.g. 3 seconds, it will only let me lift them for 3 seconds. But since the blinds move slower up than down, they do stop before being fully lifted.
Even after researching the topic for a couple of hours, I did not find a solution for this.
Did you find a solution? I had the same problem today but I don’t have any setup configured since I don’t have Internet at home yet.
I did not find a solution and will probably order some different modules. Hopint that they behave differently.
