Controlling Ecowitt (Froggit, Ambient) subdevices
I would like to introduce the product of a side-project of mine: Ecowitt-Controller.
It’s basically ecowitt2mqtt (well, not entirely but that was initial inspiration) but allows you to control subdevices such as WFC01 and AC1100. It’s written in dotnet, runs in a container and auto-discovers multiple gateways and subdevices. All gateways and subdevices are available to HomeAssistant via MQTT Discovery.
Link to project: GitHub - mplogas/ecowitt-controller: Read and control Ecowitt weatherstation and subdevices
I would like to invite the community to find bugs and improve documentation
How to get started:
  1. create an appsettings.json file.
    minimal config (check the documentation on GH for other options):
     "mqtt": {
         "host": "",
         "user": "",
         "password": ""
  2. docker run -v /path/to/appsettings.json:/config/appsettings.json -p 8080:8080 --name ecowitt-controller mplogas/ecowitt-controller:latest
  3. open the Ecowitt gateway Web-UI (or use the WSView Plus app and select your gateway) and select Weather Service - Customized
  4. set the following options (modify the IP to your docker host):
  5. within a minute (if you’re running auto-discovery) Home Assistant should pick up all your gateways and their subdevices:
I am running this in production for a few days now and I have tested with GW1000 and GW2000 gateways (and WFC01 and AC1100 subdevices).
I added dynamic sensor discovery, but I don’t have all available sensors, so I need your help :slight_smile:
Let me know what you think and post issues to GitHub.
Thanks!
@mods:Please move this post to “Share your Projects” if you feel it would be a better fit.
