Skye
August 29, 2021, 1:14pm
1
I thought the Google Assistant integration could also expose Google Home devices to HA so HA could control them but I believe I am wrong in this?
I have a device that works with Google Home but does not have HA integration/support. Is there a way to use Google Home as a kind of middle man?
Tinkerer
(aka DubhAd on GitHub)
August 29, 2021, 4:41pm
2
Correct, you can’t do that - Google don’t provide any way of doing it.
Skye
August 30, 2021, 11:23am
5
Daikin Perfera airco/heatpump
Hellis81
(Hellis81)
August 30, 2021, 12:43pm
6
There seems to be IFTTT support.
Daikin Online Controller works better with IFTTT
So you probably can activate the IFTTT applets from HA using the IFTTT integration.
rossk
August 30, 2021, 8:50pm
7
Although no longer maintained it still works perfectly, try looking in to “assistant relay” in the HACS
Skye
September 11, 2021, 6:43am
8
I had a look but it seems outdated. To connect you need a “out of home” ID, which since their screenshots of the app are very outdated, is impossible to find in the app.
