Controlling House Alarm From HA
Hi. Do you mean the yaml part in HA?
Hi Rune, I use this Alarm System (https://github.com/runningman84/home-assistant-apps/blob/master/apps/alarm.py) that automatically arm and disarm alarm based on device_tracker recognition of my smartphone (when works fine). I wish an alternative way to arm and disarm it using RFID badge or tag.
I’ve a RC522, a Nodemcu V3 Lolin and I wish to use the firmware and scripts created by thaijames to integrate them in my Home Assistant.
I’m a newbie please help me…
There is a firmware to flash in Nodemcu to send RFID token to HA
(Controlling House Alarm From HA)
There is a code to interface RFID reader to HA …I suppose to put in a file like… rfid.py
Where should this file be put?
Then there is some automation to put in configuration.yaml to arm or disarm alarm
My alarm code is based on appdaemon and is located in /config/appdaemon/apps/alarm.py
Usually I arm or disarm it using automations…
      - service: alarm_control_panel.alarm_arm_home
        data: {"entity_id":"alarm_control_panel.ha_alarm","code":"12345678"}
or
      - service: alarm_control_panel.alarm_disarm
To simplify operations at the moment I wish to exclude the management of the LEDs
Can you help me?
I uploaded the sketch I used to the NodeMCU and then received RFID ids as MQTT messages to HA. Based on these ids I made automations to turn on if off and off if on. No fancy stuff ;) I only use the LEDs to show if the alarm is on or off. If you dont want to use LEDs just dont connect anything to these outputs.
I filled mqtt server data and flashed the Nodemcu commenting the code about leds management…
and now?
how to integrate it in HA?
How to authorize only my rdif badge?
How to do to arm/disarm my alarm?
My firmware version now is…
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <SPI.h>
#include "MFRC522.h"
/* wiring the MFRC522 to ESP8266 (ESP-12)
RST     = GPIO4
SDA(SS) = GPIO2
MOSI    = GPIO13
MISO    = GPIO12
SCK     = GPIO14
GND     = GND
3.3V    = 3.3V
#define RST_PIN  D3 // RST-PIN GPIO4
#define SS_PIN  D8  // SDA-PIN GPIO2
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
// Wifi Connection details
const char* ssid = "TIM-12345678";
const char* password = "aabbccddeeffgghhiijjkkll";
const char* mqtt_server = "192.168.1.2";
const char* mqtt_user = "user";
const char* mqtt_password = "12345";
const char* clientID = "RFID";
const char* rfid_topic = "home/rfid";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
void setup() {
  Serial.begin(115200);
  SPI.begin();           // Init SPI bus
  mfrc522.PCD_Init();    // Init MFRC522
  delay(2);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
// Connect to Wifi
void setup_wifi() {
  //Turn off Access Point
  WiFi.mode(WIFI_STA);
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println();
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
// Check for incoming messages
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.println("");
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.println();
  char s[20];
  sprintf(s, "%s", payload);
    if ( (strcmp(topic,"home/alarm")==0))
    payload[length] = '\0';
    String sp = String((char*)payload);
  // Alarm is off
    if (sp == "disarmed")
    Serial.println();
    Serial.print("Alarm is set to Disarmed");
    Serial.println();
    //off_both_led();
  // Alarm is Armed Home
    else if (sp == "armed_home")
    Serial.println();
    Serial.print("Alarm is set to Armed Home");
    Serial.println();
    //on_green_led();
  // Alarm is arming
      else if (sp == "pending")
    Serial.println();
    Serial.print("Alarm set to Pending");
    Serial.println();
    //on_both_led();
  // Alarm is Armed Away
    else if (sp == "armed_away")
    Serial.println();
    Serial.print("Alarm set to Armed Away");
    Serial.println();
    //on_green_led();
  // Alarm is Triggered
    else if (sp == "triggered")
    Serial.println();
    Serial.print("Alarm is triggered!!");
    Serial.println();
    //on_red_led();
/* interpret the ascii digits in[0] and in[1] as hex
* notation and convert to an integer 0..255.
int hex8(byte *in)
   char c, h;
   c = (char)in[0];
   if (c <= '9' && c >= '0') {  c -= '0'; }
   else if (c <= 'f' && c >= 'a') { c -= ('a' - 0x0a); }
   else if (c <= 'F' && c >= 'A') { c -= ('A' - 0x0a); }
   else return(-1);
   h = c;
   c = (char)in[1];
   else return(-1);
   return ( h<<4 | c);
// Reconnect to wifi if connection lost
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect(clientID, mqtt_user, mqtt_password)) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      client.publish("home/rfid", "connected");
      // ... and resubscribe
      client.subscribe("home/alarm");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
// Main functions
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    delay(50);
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial()) {
    delay(50);
    return;
  // Show some details of the PICC (that is: the tag/card)
  Serial.println("");
  Serial.print(F("Card UID:"));
  dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
  Serial.println();
  //digitalWrite(idPin, HIGH);
  delay(500);
  //digitalWrite(idPin, LOW);
  delay(500);
  // Send data to MQTT
  String rfidUid = "";
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    rfidUid += String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : "");
    rfidUid += String(mfrc522.uid.uidByte[i], HEX);
  const char* id = rfidUid.c_str();
  client.publish("home/rfid", id);
  delay(3000);
// Helper routine to dump a byte array as hex values to Serial
void dump_byte_array(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], HEX);
Hi, I will find my old configuration and automations and put it here (I removed my RFID since I got my device tracker working properly). Could you confirm that you have hass.io and Mosquitto MQTT broker? The alarm also needs to be Manual alarm with MQTT.
Yes, I use Hassio and Mosquitto MQTT broker.
I can arm or disarm alarm manually… usually I ise a Xiaomi wireless switch with a automation like this…
  - alias: SystemAlarm Disarmed Manually
      platform: event
      event_type: click
      event_data:
        event_id: binary_sensor.switch_123456789123456789
        click_type: double
      data: {"entity_id":"alarm_control_panel.ha_alarm","code":"12345"}
After flashing Nodemcu what will be his IP?
I do not see it in my wifi network… it is strange…
When you flash it with the sketch you can have the log open, there you will see if it connects and which IP it receives.
After flashing in serial monitor of Arduino IDE it printed… ⸮8⸮⸮⸮
I fear there is something wrong with the firmware
Hi, did you remember to set it to speed to 115200? If this is your first time using arduino watch this video. It helped me alot: https://www.youtube.com/watch?v=jpjfVc-9IrQ&t=662s
I used many time Arduino IDE, I flashed with Tasmota 8 Sonoff switches few months ago.
Serial speed is 115200
huh. Then I dont get it. It works fine for me on NodeMCU. I can retry the sketch a bit later tonight and see what I find. I remember all my sketches always start with some like ???something, but then goes over to normal.
Hi Rune, I solved the problem… the Nodemcu V3 was partially broken… I flashed the blink sketch and it do not blink the led.
Now I tested with a ESP8266 D1 mini and it works fine and is recognized from my wifi network and assigned a IP. If I use a badge or tag it show me its code in the Arduino serial monitor.
Mosquitto MQTT view it… “New client connected from 192.168.1.133 as RFID (c1, k15, u’vpomax’).”
Now I need to make the code HA side.
I used the sensor to have a view of what I received in HA and the automation below for the alarm. Just replace RFIDxxxxxx with the ID that shows in the sensor. Goodluck :slight_smile:
Sensor:
      - platform: mqtt
        state_topic: "home/rfid"
Automation:
    - alias: RFID 1 Alarm off
        platform: mqtt
        topic: "home/rfid"
        payload: 'RFIDxxxxxx'
      condition:
        condition: or
        conditions:
          - condition: state
            entity_id: youralarmhere
            state: armed_home
          - condition: state
            state: armed_away
        - service: notify.ios_yourphone
            message: "RFID 1 -> Alarm off!"
        - service: logbook.log
          data_template:
             {{ MQTT }}
            message: RFID 1 -> Alarm off!
            code: myalarmpassword
    - alias: RFID 1 Alarm on
        platform: mqtt
        topic: "home/rfid"
      condition:
        - condition: state
          state: disarmed
        - service: notify.ios_xxxxx
            message: "RFID 1 -> Alarm on!"
          data_template:
             {{ MQTT }}
            message: RFID 1 -> Alarm on!
            code: youralarmpassword
HA called it sensor.rfid__c
the RFIDxxxxxx code is the code of the badge? e.g RFID95a6c81f ?
Sounds correct, but without the RFID part. Just the random letters and numbers.
WOW!!! it works fine!!! :smiley:
it was more easy than I thinked
Thank you Rune for support… you have been very helpful and patient :+1:
I will use it in alternative to device_tracker becouse sometimes device_tracker do not recognize smartphone when we return at home, so I need a fast way to disarm it
Thanks for the great contribution to the original post, it’s more than great!
I have this now setup, but have 2 questions:
  • The blue light is working for me (the one that turns ON when it reads a tag). I know you disabled the red&green leds on purpose, but could you describe exactly why? And how could I enable them again by using your code?
  • I don’t understand the part on your code that says “code: youralarmpassword”. What is exactly that alarm for? In my setup I just have the following in configuration.yaml and seems to be more than enough:
alarm_control_panel:
  platform: manual
  pending_time: 0
  trigger_time: 1 # Workaround to prevent being in the triggered state
Thanks a lot!
Hi. All the LEDs should be working with the sketch, but without the blinking. I use Manual Alarm Panel with a password (optional), since you dont have password you dont need that line (Manual Alarm Panel).
Hum… strange only the blue one is working with me.
Anyway, what sketch are you refering to?
Thanks.
Hi
As you can see below in the sketch I have assigned D0 , D1 and D2 to the LEDs.
