I’m curious if anyone has any tips on making the (awesome) Hunter Douglas Powerview Integration work with the Hunter Douglas “Top Down Bottoms Up” blinds?
The current integration only allows you to control the “Top Down” element:
My proposed solution — which sadly, I am not technically savvy enough to implement, is:
- Allow cover positions to be dual — so rather than simply setting a position as “75”, you’re able to set the position to be “75, 65” which would designate the top rail and then the bottom rail.
Another option would be to have the top and bottom rails appear as two independent covers — this is what Homekit does.
Really hope we can figure this out. Thank you!!
