Controlling LED strip via modbus
I’m using this custom component to create modbus slaves from my ESP - GitHub - epiclabs-uc/esphome-modbus-server: ESPHome Modbus Server component.
This is a part of my slave YAML file:
external_components:
  - source: github://arpiecodes/esphome-modbus-server@master
    refresh: 3d
    components:
      - modbus_server
uart:
  tx_pin: 1 #TX
  rx_pin: 3 #RX
  baud_rate: 115200
modbus_server:
  - id: modbuserver
    uart_id: modbus_serial_port
    address: 2 # slave address
    #de_pin: 17
    #re_pin: 17
    holding_registers:
      - start_address: 1 # in this example we map register 200 to a switch
        number: 1
        on_write: |
          ESP_LOGI("ON_WRITE", "This is a lambda. address=%d, value=%d", address, value);
          if(value)
            id(led_strip)->turn_on();
          else
            id(led_strip)->turn_off();
          return value;
        on_read: |
          return id(led_strip)->state ? 1 : 0;
      - start_address: 2
        number: 1
        on_write: |
          if(value)
            id(wlan)->enable();
          else
            id(wlan)->disable();
          return value;
        on_read: |
          return id(wlan)->is_disabled() ? 0 : 1;
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2812
    pin: GPIO4
    num_leds: 26
    effects:
      - random:
      - strobe:
      - flicker:
      - addressable_rainbow:
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
I would like to control the LED from my MASTER esp but I’m not sure if it’s possible. As you can see, I tried to atleast turn on/off the LED in the address 1 but that didn’t work. Is there a way to control the LED from the MASTER with all the functionality(color change,brightness etc.)?
