My old door opener had a simply relay interface which I could control with a doorbell button and/or a relay switch. So I had built a garage door controller with a relay switch and a Raspberry Pi. It worked perfectly for years. Now I have myq and it fails when they decide they want to change the API. So I want to reinstall my relay switch setup.
However I don’t think the new opener will work with a simple relay. The wall switch is wired to two terminals but the wall switch controls several features of the opener including putting it in learning mode, etc. So I don’t think the terminals are as simple as the previous.
Anyone now how I can attach the relay from the raspberry to this opener or do I have to hack a garage door opener into my system?
The opener is an Raynor Admiral II.
Which is really just this Liftmaster model.
The connection is on page 15.
I think I have to hack in a remote but hoping there is a way to just connect directly to the unit.
Yea so far my research says hack a remote or hack into the wall switch. I like wall switch because no battery to manage but if I mess up wall switch replacement is pricy. I have two extra remotes so that seems the way to go.
I don’t understand why garage door openers don’t have the terminals for a standard open/close relay anymore. I makes it so much easier to attach a device if they do. It’s pure greed so you have to purchase one of thier “official” buttons or devices. OK I guess I do understand just don’t like it. Have to get myself a good soldering iron now.
I believe greed may be a possibility but supposedly the newer control systems are more “secure” since they need a “rolling code” switch even for the hardwired switches. That’s part that makes no sense.
I can understand the security enhancements for the remote control because it makes it (almost) impossible for someone to sniff your code & get in later. But if they have access to the hardwired switch inside your garage/house then your security is already breached and then who cares if they can hack your garage door opener.
