Controlling the fan seems to work, when I move the slider up, the fan increases it’s speed, when I move it down, it decreases it’s speed. I am however facing 2 issues:
All Noctua fans provide a tachometer output signal of the following characteristics:
• two cycles per revolution
When I have a look at the log when the fan is running at full speed, I see that the pulse counter is all over te place:
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 3348.00 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 1674.00000 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 3779.24 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 1889.62207 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 4132.13 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 2066.06616 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 3894.55 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 1947.27380 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 3649.46 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 1824.72986 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 4120.12 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 2060.06006 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 3888.00 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 1944.00000 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 4700.24 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 2350.11987 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 5704.56 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 2852.28174 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 12396.00 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 6198.00000 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 11397.72 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 5698.86035 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 11978.40 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 5989.19775 RPM with 2 decimals of accuracy
[D][pulse_counter:174]: 'Fan Speed': Retrieved counter: 11604.00 pulses/min
[D][sensor:126]: 'Fan Speed': Sending state 5802.00000 RPM with 2 decimals of accuracy
The other issue I have is that when I set the fan to off / 0, it still keeps spinning. Any idea what the issue could be? I tried playing around with the “min_power”, but that doesn’t seem to help.
I have the fan connected to a 12v power supply, while the D1 mini gets it’s power via USB. I have the GND’s of the 2 power sources wired to eachother.
I think I’ve figured it out. The rpm’s where not right, because I did not add the resistor between the rpm pin and the 12v line, like in the schematic in PWM Fan Controller.
The problem with not being able to stop the fan completely seems to be that these Noctua fan’s don’t support anything below 20%, I fount this in a datasheet:
Operation below 20% PWM duty-cycle is not officially supported in the Intel specification
(undefined behaviour). However, most Noctua PWM fans can be operated at below 20%
and will stop at 0% duty-cycle. Only the following models keep running at their specified
minimum speed when the input is below 20%: NF-A20 PWM, NF-S12B redux 1200 PWM
and NF-B9 redux 1600 PWM
So I’ve now added a relay to be able to stop the fan. Now just got to clean this mess up befor I install it in my cabinet
Hello. I try now, as you to control Noctua NF-P12 redux-1700.
Made quick test, without resistance.
What value of resistance you used and it is connected to tachometer
update. I use 4k resisto pull up and +3.3v on, tachometer fan pin, and it return right rpm, only with fan at 100% power. To low power, values, are not relly.
I will try 1k resistor.
I managed to make this work without needing a resistor, using the pullup resistor on the pin, see code below.
I had issues at first because I was powering the esp with a separate usb wall ps and without having a common ground the Noctua wasn’t powering off, but now that I’ve used a buck converter from 12V to 3.3v for the esp everything works.
That’s great, thanks for confirming that. I want to also try with an ESP32 and see if it makes a difference in the noise level of the fan.
The ESP8266 Software PWM Output doesn’t state the hz range in the docs, but I’ve read multiple times that it maxes out at 1000hz as it’s only software while the ESP32 is hardware.
By Noctua specs which follow Intel specification, PWM Target frequency: 25kHz, acceptable range 21kHz to 28kHz. From my test it works perfectly with the ESP8266 Software PWM set to 25000 hz, I don’t know of a way to actually test the frequency, but if it actually goes at 1000 hz I would expect to have a worse noise level or pitch. Maybe the Noctua fan I tested was fine but others might differ.
It would be great if there was a way of actually measuring the pwm signal, otherwise I guess it’s just safer to use and ESP32.
I’ve built a custom PCB breakout that supports both the D1 mini and the 20 pin variant in the same form factor like here. If anyone is interested I can upload the PCB build files to git. It’s kinda nice with about 8 JST breakout headers for analog, 2x I2C headers with 2 different formats, jumpers to select 3.3v or 5v. A logic level shifter with 2 outputs supporting up to 3A @ 5v for NeoPixels and a Mosfet header to switch loads on/off and a few other generic headers for whatever you want. Input voltage can be as high as 35v if you choose the LM7805. Otherwise 12v input using the AM11173.3v.
Yeah I know there is a lot of debate with 7805 and ams1117, but they are simple, reliable and easy to solder.
I am generally moving to ESP32 for everything as the $1 difference is more than reasonable but having flexibility for ESP8266 for super simple stuff is nice.
My testing was with a Noctua NF-A14x25. Zero hissing/whining or any other noises. The end goal is 2 NF-A6x25. The NF-A6’s are on order and I can give feedback when they arrive. PS: I used 25000Hz
The last step here will be getting HA to adjust fan speed dynamically based on temperature readings in the AV cabinet.
Sounds interesting, I was working on a simple pcb too a few months ago with a ESP8266, but didn’t get it to work properly (didn’t boot into programming mode, so I probably made a mistake somewhere in the board)
I have build just about the same, but with a different approach. I just soldrn an existing D1 on the PCB I created.
I also have a switch on it that can drive multiple fans. Up to about 5 amps. Everything is build in EasyEda. I can share Gerber files if you are interested.
More details, including ESPhome config on my GitHub:
I absolutely will. I made a couple of changes mainly to simplify the power input. I won’t be able to test the new PCB’s until the first week of March. I’ll add to my github and share that link here. thx
