Hey all ESP homies (get it? )
I’m working on a robot garage for my vacuum. It’s based on this design but I’m having some major issues.
So I reverted just to create Proof-of-concept first, so I followed this guide. However, when I call the service through the developer tools I get this error:
Failed to call service esphome.livingroomgarage_control_servo. Unknown error
It seems to be the same whether or not the controller is on or off. What am I missing here?
Hardware:
JCPower 5v 10A power supply
MG996R servos
NodeMCU
I use this wiring;
YAML:
esphome:
platform: ESP8266
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
services:
- service: control_servo
variables:
level: float
then:
- servo.write:
level: !lambda 'return level / 100.0;'
ota:
wifi:
ssid: xxx
password: xxx
manual_ip:
static_ip: 192.168.1.102
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Livingroomgarage"
password: xxx
captive_portal:
output:
- platform: esp8266_pwm
pin: D3
frequency: 50 Hz
servo:
- id: my_servo
output: pwm_output
