Hi all! I have now installed some thermostats in home assistant. They keep the temperature and regulate it, so far it works very well!
i would like to control some of the thermostats on a time basis (bedroom thermostat from X clock to Y clock on 21 degree celcius). i find automation settings and scripts under the device settings, but nothing where i can set times. do i need any timers/actions for that?
You could add time conditions to automations using platform: timeā¦
- alias: HVAC Winter Evening
platform: time
at: "17:00:00"
- service: climate.set_temperature
entity_id: climate.home_hvac
temperature: 19
Thank you! in which file are the automations created? automations.yaml or configurations.yaml?
automations.yaml
I already use smart thermostats (Honeywell) so this doesnāt apply to me right now, butā¦
Every smart thermostat Iāve heard of comes with an app or other easy way for non-techies to establish and change a daily and weekly schedule. Itās really the whole point of a smart 'stat.
It seems sort of primitive to have to write code (automations) to do this. Of all the great things HA can do, this is a glaring omission.
Has this already been done and Iām just missing something?
via custom components afaik. schedy
Thanks, thatās pretty slick. But then again, Iām a coder from way back. I was thinking more in terms of a GUI-fied process for the masses. Here are a couple of screen shots from my Honeywell thermostat web-based configuration screen. Thereās an app too, which does similar things. I find this pretty primitive, with a limited number of changes allowed, but I guess that keeps it simple. Iām sure with the talent here, we could do better!
I think you can find similar projects in āshare your projectā - have you tried?
Or maybe you can do it and share with us?
I personally donāt need such a complex scheduler and just made a night/day preset/automations for my central heating. Donāt have time for more, prioritiesā¦
thank you, that was the answer. it works so far! i would like to change the hvac_mode from āautoā to āheatā at 5 oāclock. after 15 minutes i would like to switch back to āautoā. how can i change this in the config? āautoā should stay at 20 degrees.
automation:
- alias: Bathroom warm
platform: time
at: "05:00:00"
entity_id: climate.thermostat_bathroom
temperature: 25
- alias: Bathroom normal
platform: time
at: "05:45:00"
temperature: 20
call climate.set_hvac_mode?
hint: open Developer Tools ā Services and type in set_hvac and youāll see what it needs as arguments.
Do ask if you need further assistance.
