Controlling WS2812 using USB-C
Hi everyone! I’m sharing my new dual channel USB-C LED controller that I initially made to simplify some of my installations.
It can be powered through the Power Delivery protocol up to 100W and the main thing is that it has an on-board buck converter that can regulate the output to 5 or 12V (max 20A) taking advantage of a lot of current for the connected strips.
You can also power it through the barrel jack while using the USB-C to program the ESP32-S3.
Actually I’m using it with the latest WLED beta with audio reactive usermod and it works great!
It also has a full feautered set of protections plus other nice functions.
It’s a complete open-source project and If you are interested you can find here the whole documentation I’m working on to explain all the things this controller can do!
Consider Share your Projects! - Home Assistant Community category for this…
Might be a better fit.
