Convers Groups
Hello
I’m here with a problem using group cover,
I have this group
      - platform: group
        entities:
          - cover.estore_suite
          - cover.estore_leonor
          - cover.estore_quarto
          - cover.estore_sala
This group controls those blinds, but I have some inputs to facilitate user manager
    input_select:
      estore_sala_actions:
        options:
          - "Fechado"
          - "Entreaberto"
          - "25%"
          - "50%"
          - "75%"
          - "Aberto"
          - "Manual"
One for each input
My problem is that I have an automation to update the status of the inputs depending on the position of the cover
 - alias: "Estores :: Inputs Acções Definir Valor"
          - platform: state
            entity_id: cover.estores_quartos_sala
          - platform: state
            entity_id: cover.estore_cozinha
          - platform: state
            entity_id: cover.estore_leonor
          - platform: state
            entity_id: cover.estore_quarto
          - platform: state
            entity_id: cover.estore_sala
          - platform: state
            entity_id: cover.estore_suite
          - platform: state
          - service: input_select.select_option
            data_template:
              entity_id: input_select.{{ trigger.entity_id.split(".")[1] }}_actions
              option: >
                {% if trigger.to_state.attributes.current_position | int == 100 %}
                  Aberto
                {% elif trigger.to_state.attributes.current_position | int >= 14 and trigger.to_state.attributes.current_position | int <= 16 %}
                  Entreaberto
                {% elif trigger.to_state.attributes.current_position | int >= 24 and trigger.to_state.attributes.current_position | int <= 26 %}
                  25%
                {% elif trigger.to_state.attributes.current_position | int >= 49 and trigger.to_state.attributes.current_position | int <= 51 %}
                  50%
                {% elif trigger.to_state.attributes.current_position | int >= 74 and trigger.to_state.attributes.current_position | int <= 76 %}
                  75%
                {% elif trigger.to_state.attributes.current_position | int == 0 %}
                  Fechado
                {% else %}
                  Manual
                {% endif %}
This works well for all inputs except for the cover group
But if I do a new automation like this:
      - alias: "Estores :: Inputs Acções Definir Valor Grupo de Estores"
          - platform: state
            data_template:
              option: >
                  Aberto
                  Entreaberto
                  25%
                  50%
                  75%
                  Fechado
                {% else %}
                  Manual
                {% endif %}
Everything works correctly, but I didn’t want to be duplicating code because afterwards it is more complicated to manage
Another problem I have with the groups Is that sometimes 1 of the windows does not change the position, all but 1 change (Random)
Any hints?
