I tried to add custom phrases into the conversation component but it is not working. Anyone has any luck?
i got the same problem’
i tried the following:
configuration.Yaml:
conversation:
intents:
Woonkamerlampen:
- Woonkamer lampen ingeschakeld`
intent_script: !include intent_script.yaml
in my intent_script.Yaml. i got te following:
intent_script:
Woonkamerlampen:
speech: Woonkamer lampen aan.
card:
type: simple
title: Lights Card
content: De woonkamer lampen zijn ingeschakeld.
service: light.toggle
entity_id: light.woonkamer
i must be doing something stupid.
Same here.
Tried to copy-paste the example from docs but get the following error:
2018-02-25 15:59:34 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
2018-02-25 15:59:34 ERROR (MainThread) [homeassistant.config] Invalid config for [conversation]: [boolean_test] is an invalid option for [conversation]. Check: conversation->conversation->boolean_test. (See /mnt/hass/configuration.yaml, line 272). Please check the docs at https://home-assistant.io/components/conversation/
2018-02-25 15:59:34 ERROR (MainThread) [homeassistant.setup] Setup failed for conversation: Invalid config.
I think all text with spaces such as in
should be in quotes:
speech: "Woonkamer lampen aan."
content: "De woonkamer lampen zijn ingeschakeld."
