Conversion from wh to kwh meross socket
immagine
guys who helps me in converting wh to kwh? I used this text but it is not good, it gives me high consumption that if I do the conversion they are not true …
You don‘t need the unit: kWh because the integration platform will calculate it for you. Also the unit should be kWh and not kwh.
