Conversion of sensor values
I have a problem, think it would be easy to solve, but I just can’t get it.
I have a sensor that responds to on / off and simply counts it up (Tasmota / Counter) this value should now be converted and output on a new virtual sensor.
I made the following template for this, but it doesn’t work.
I created this sensor in my configuration.yaml:
platform: template
    sensors:
        friendly_name: "laufende Meter"
        unit_of_measurement: 'm'
        value_template: "{{ states('sensor.d1pro_counter_c1') | float * 0.12 | float }}"
Where is my mistake?
Thank you greetings
Gerald
Have a look at this:
    sensors:
      laufende_meter:
Edit: seems this is a legacy format. It is working, but there is a new way to do it:
template:
  - sensor:
      - name: "laufende Meter"
        unit_of_measurement: "m"
        state: "{{ states('sensor.d1pro_counter_c1') | float * 0.12 | float }}"
More info in Template - Home Assistant
Thanks!
Both worked wonderfully :slight_smile:
Just FYI that last float filter is redundant. You can remove it. You don’t need to do that to numbers. Only states.
