Greetings, I am unable to use a thermostat card even though I have a Nest connected and providing accurate information. The card reports that I must use entities from the climate domain.
I have tried using templating with no luck. Is it possible to convert these items to a climate domain or use virtual devices with a thermostat card?
Thank you for your input. The Nest data is pulled from a Homeseer system. This seemed the only way to get the Nest data into HA. Unfortunately if I move to the newer Nest API, my Homeseer system will loose access to the thermostat permanently. Thanks to Google.
