I have a light (appears to be an LED strip of sorts but it’s appears like a continuous strip rather than individual LEDS).
It’s powered by 3 AAA batteries (1.5v) and the battery is connected to a basic on/off switch which is connected to the LED strip.
I’m wanting to convert this to be Wi-Fi enabled and bring it into HA, it doesn’t need to be battery powered and I’m ok with using a usb to power it. I also don’t need to make use of the physical switch.
I assume I need a 5v output from an esp or nodemcu but I’m not sure on the wiring setup needed to take a battery powered light and incorporate an esp module.
