Hey,
I currently have an automation, which should change the brightness. My data template creates a float, which is not assignable to the brightness / int.
I tried to use use the integer pipe to convert it but without any success.
- alias: Test
- platform: state
entity_id: sensor.temperatur
- service: light.turn_on
entity_id:
- light.test
data_template:
brightness: '{{ (float(states.sensor.kallax_temperatur.state) - float(states.sensor.temperature_158d0002027f49.state)) * float(100) + 220 }}'
Is there any way to convert it?
Thanks in advance
