Using this code:
on_value:
then:
- mqtt.publish_json:
topic: domoticz/in
payload: |-
root["idx"] = 259;
root["nvalue"] = 0;
root["svalue"] = id(roomtemp).state;
My mqtt subscriber gets this payload:
{“idx”:259,“nvalue”:0,“svalue”:20.125}
The problem is I need the temperature (20.125) to be a string such that in the payload it has quotes around it like this:
{“idx”:259,“nvalue”:0,“svalue”:“20.125”}
Can someone please help me solve this? Thank you.
Karosm
(Karosm)
December 20, 2024, 1:15pm
2
try if it accepts:
id(roomtemp).state.c_str()
That does not work. I forget the exact error because I had tried that a while ago. Thank you though.
mulcmu
December 20, 2024, 1:58pm
4
Did you try if the payload will take an Arduino String class? Below code will initialize the String to the numeric value in the parameter. If the payload needs a c string the .c_str()
can be added after the last )
. For idf framework might need to add correct #include or use std::string.
root[“svalue”] = String( id(roomtemp).state );
That worked! How simple. Here’s the working code:
- platform: dallas_temp
name: "Room Temperature"
update_interval: 10s
on_value:
then:
topic: domoticz/in
payload: |-
root["idx"] = 259;
root["nvalue"] = 0;
root["svalue"] = String(id(roomtemp).state);
A payload of {“idx”:259,“nvalue”:0,“svalue”:“20.125”} is delivered. Thank you so much!
