Convert from tasmota TuyaMCU/tuyasend to ESPHOME
Hi all,
in your opinion it would be possible to convert this tasmota template into ESPHOME.
In my device I would prefer to load ESPHOME.
I saw that Esphome has Tuya components but they accept different parameters than Tasmota ones.
thank you so much
but for example which gpio should I indicate for the uart?
in the Tasmota template are not indicated!
I think you’d need to look at the BASE, which is 54 - which is documented https://tasmota.github.io/docs/Modules/
