Hi Team,
Need some help with converting GPS coordinates to something that Home assistant maps can hopefully use.
ESPHome config:
gps:
latitude:
name: "${friendly_name} Latitude"
longitude:
name: "${friendly_name} Longitude"
The above outputs in the following format:
latitude: -12.345678
longitude: 123.456789
I would like to convert the latitude and longitude into a new string called “location” which should be in this format: -12.345678, 123.456789
Assume this will be in text_sensor: lamdba, but not sure how to write this.
Thanks in advance
ckxsmart
(CK Smart)
2
This is the lambda code that you can use in the text template sensor:
text_sensor:
lambda: |-
char buf[50];
sprintf(buf, "%f, %f", id(latitude).state, id(longitude).state);
return buf;
Hi there,
Thank you for your reply.
This is the errors that I am receiving when compiling the code:
Compiling /data/test/.pioenvs/test/src/main.cpp.o
/config/esphome/test.yaml: In lambda function:
/config/esphome/test.yaml:67:14: error: could not convert 'buf' from 'char [50]' to 'esphome::optional<std::__cxx11::basic_string<char> >'
67 | return buf;
| char [50]
*** [/data/test/.pioenvs/test/src/main.cpp.o] Error 1
Config used:
text_sensor:
lambda: |-
char buf[50];
return buf;
Any ideas?
Jpsy
(Jörg Wagner)
4
I am not at all a C++ expert, but try one of these:
return { buf };
return { buf.c_str() };
ckxsmart
(CK Smart)
5
My bad, change the last line to
return std::string(buf);
Thank you. This is working now.
Working GPS code:
substitutions:
device_name: gps
friendly_name: "GPS"
esphome:
friendly_name: ${friendly_name}
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret api_key
reboot_timeout: 0s
# Enable OTA
ota:
safe_mode: true
password: !secret ota_password
wifi:
networks:
- ssid: !secret wifi_ssid
domain: !secret wifi_domain
ap:
ssid: "${friendly_name} Fallback"
password: !secret wifi_fallback
captive_portal:
# Enable Webserver
web_server:
port: 80
text_sensor:
- platform: wifi_info
ip_address:
ssid:
bssid:
mac_address:
- platform: version
lambda: |-
char buf[50];
# Status LED
status_led:
pin:
number: GPIO2
inverted: yes
# Reset Button
button:
- platform: restart
# GPS Module configuration entry
uart:
rx_pin: GPIO4 #D2
tx_pin: GPIO5 #D1
baud_rate: 9600
#wifi signal Sensor
- platform: wifi_signal
name: "${friendly_name} WiFi Signal"
#Uptime Sensor
- platform: uptime
# Declare GPS module
gps:
update_interval: 30s
latitude:
longitude:
course:
altitude:
name: "${friendly_name} Altitude"
speed:
satellites:
name: "${friendly_name} Satellites"
