Convert Hex to dec
Hi, i have an hex value in my sensor … how can i convert it to an decimal integer, so i can use it with a shell command?
thnx in advance
i want to change the state of an light (brightness) so from 0 … 255 , but i only have at the moment the HEX value coming from my domotica
{{ states(ENTITY_ID)|int(base=16) }}
thnx already
will the below command work? i use those curl scripts succesfull for normal lights where i need to set JUST the state to on or off, but now i also need for some dimmerlights the brightness
also i get a HEX value back from my system 00 to 64 (in hex) , thats from 0 to 100
so i need to recalculate it, so i can send a decimal value between 0 … 255 back for brightness …
is this the correct approach?
dimmer1_on: "curl -k POST -d '{\"state\": \"on\",\"attributes\": {\"brightness\": states.sensor.Prog.state|(int(base=16)/100)*255}}' https://127.0.0.1:8123/api/states/light.dimmer1?api_password=blabla"
ok, it doesnt work :slight_smile:
also this doesnt work :frowning:
(states('sensor.Prog.state[36:38]')|(int(base=16))/100*255
dimmer1_on: "curl -k POST -d '{\"state\": \"on\",\"attributes\": {\"brightness\": {{states.sensor.Prog.state|int(base=16)/100*255}}}}' https://127.0.0.1:8123/api/states/light.dimmer1?api_password=blabla"
damnit , forgot those ninja {{}} things :frowning:
got it to work now, thnx a lot!!!
lol. I think you mean Jinja. :wink:
Glad you got it working!!
Yeah :wink:
Thnx
