shaps
1
I’m using some power switch that returns real time power consumption in W
I would like to graph and keep the statitstic for hourly, daily, monthly, yearly for each power switch
I check with utility meter but I don’t understand how to do this conversion
Thank you
Best regards
Nicolas
First, you can convert it to kWh using Riemann Sum. You should also use the “left” method for a more accurate result.
Then, you can use Utility Meter track the consumption.
shaps
3
I just tried the 2 modules
Let’s see in 15 minutes if I’ve some results
Thank you
