Jo-AnB
(Jo-An)
June 25, 2022, 9:51am
1
I have two button-cards which i use to display the number of switches and devices in a certain area in a button card custom field.
The area is a var declared on the main button card.
I have a jinja template to get the values, but i’m having trouble converting them to javascript templates.
Can someone help me out?
{{ states | selectattr('domain', 'eq', 'switch') |
map(attribute='entity_id') | map('area_id') | select('eq', '[[[ return variables.var_area ]]]') | list | count }} switches
AND
{{ area_devices('[[[ return variables.var_area ]]]')|count }}
devices
petro
(Petro)
June 25, 2022, 10:02am
2
those will be extremely complex JS templates if you try to convert them. The second one isn’t even possible to convert because JS doesn’t have access to Jinja methods, i.e. you can’t use the area_devices
function.
I recommend you create template sensors with this information and then use those in the JS templates.
EDIT: The first one isn’t possible either because you’re using mapping to area_id
. So, you can’t convert either of them.
Jo-AnB
(Jo-An)
June 25, 2022, 10:13am
3
Ah… i was afraid of that. I wanted to avoid having to create a sensor for each area.
Any ideas on making the sensors dynamic?
petro
(Petro)
June 25, 2022, 10:30am
4
You can create dynamic groups with an automation. Then use those in your JS templates. That’s about it.
alias: update switch area groups
- platform: time_pattern
minutes: '/1'
variables:
areas: "{{ states | map(attribute='entity_id') | map('area_name') | unique | reject('none') | list }}"
- repeat:
for_each: "{{ areas }}"
sequence:
- service: group.set
object_id: "{{ repeat.item | slugify }}"
entities: "{{ repeat.item | area_entities | select('search', '^switch.') | list }}"
I guess you could add a name to this as well, then pair it with a single template sensor that holds counts… then use that in the JS template.
automation
minutes: '/1'
variables:
- repeat:
sequence:
object_id: "switch_group_{{ repeat.item | slugify }}"
name: "{{ repeat.item }}"
template sensor
template:
- sensor:
- name: Switch Group Counts
state: >
{{ states.group | selectattr('object_id', 'search', '^switch_group_') | list | count }}
attributes:
counts: >
{% set ns = namespace(values=[]) %}
{% for s in states.group | selectattr('object_id', 'search', '^switch_group_') %}
{% set ns.values = ns.values + [ (s.name, s.attributes.entity_id | count) ] %}
{% endfor %}
{{ dict.from_keys(ns.values) }}
js template
return states['sensor.switch_group_counts'].attributes.counts[variables.var_area];
Or just go straight template sensor without the groups
template sensor
template:
- sensor:
state: >
{{ states | map(attribute='entity_id') | map('area_name') | unique | reject('none') | list | count }}
attributes:
counts: >
{% for s in states | map(attribute='entity_id') | map('area_name') | unique | reject('none') | list %}
{% set ns.values = ns.values + [ (s, s | area_entities | select('search', '^switch.') | list | count) ] %}
{% endfor %}
js template
Jo-AnB
(Jo-An)
August 21, 2022, 9:30am
5
Hi @petro ,
sorry for the late repoly. Was not able to look at this sooner. But this works great thank you.
