Hi all,
There are many posts about “how to convert w to kwh” on this topic. However, most of them end in “could you tell me how you didi it”, “how did you do this?”, etc. Most of the confusion, I think, comes from the fact that there were recently changes in the sensor template that also requires new tags (for example “total increasing” etc.).
Many youtube tutorials use the utility_meter which does not work with the energy dashboard (at least I cant find the sensor).
So, my assumption is that it would be best to use the Riemann integration.
I would therefore go the following steps:
This is my Input Sensor, quite peaky. It shows the actual kw/Power/Gas used.
to get kwh, we need to integrate this Sensor:
- platform: integration
source: sensor.actual_power
unit_prefix: k
method: left
round: 2
Here, we would be done. However, the Riemann Integration “Sensor” does not support the new “total_increasing” flag as required by the Energy Dashboard. As I understand, this can be fixed by a pseudo sensor.
Would this be the way to go then?
template:
- sensor:
- name: Gasverbrauch Dummy Sensor
unique_id: gasverbrauch_dummy_sensor
device_class: gas
unit_of_measurement: "kwh"
state: "{{ (states('sensor.gasverbrauch_kwh_integriert') }}"
state_class: total_increasing
However, it does look like this: (integration is 0 and the sensor cant be found):
Any hints?
EDIT: It turns out that using the Riemann integration is enough. I used the Helper Widget, added the Input Sensor as source and added this to the energy dashboard. Worked! Leaving this if someone is looking for the same solution.
