I’ve been using a node.js Sonos API (https://github.com/jishi/node-sonos-http-api) and I’d really like to run it as a Hassio add-on. Any guidance on how I would do that? I followed the “Hello World” tutorial for creating an add-on but that doesn’t really help me a lot.
I found a docker image of the API here (https://hub.docker.com/r/chrisns/docker-node-sonos-http-api/). I created a new add-on directory and copied the Dockerfile to my new add-on Dockerfile but it doesn’t do anything that I can see when I try and install it. It’s not showing up under my installed add-ons. I don’t see anything in the home-assistant.log.
There is a part to the instructions that reads:
Then run the docker image
docker run \
--net=host \
--name sonos \
--restart=always \
-d \
-v `pwd`/settings:/app/settings \
-v `pwd`/clips:/app/static/clips \
-v `pwd`/cache:/app/cache \
-v `pwd`/presets:/app/presets \
I have no idea how to do this. On a whim I tried adding the above to the run.sh file but that didn’t seem to do anything.
Any help would be appreciated!
