Hi folks,
now i have another problem.
One of my mqqt sensors is a temperature sensor and sends hex values above 0°C starting at #0000 …
Negative temperatures send values from #ffff down.
When I wrote the whole thing via a PHP script in an SQL database before my integration into the HomeAssistant,
I solved the problem with this code:
if (hexdec(trim(substr($parts[1],2,5)))/100 > 100){
$record[$key] = (hexdec('ffff') - hexdec(trim(substr($parts[1],2,5)))) / -100;
} else {
$dataset[$key] = hexdec(trim(substr($parts[1],2,5)))/100;
How do I manage to integrate this into the HomeAssistant in exactly the same way?
koying
(Chris B)
December 10, 2022, 11:36am
2
in a template, something like
{% set val = "#fffd" %}
Input is {{val}}
{% set valdec = int(val[1:], base=16) -%}
Decimal input is {{valdec}}
Adjusted for sign: {% if valdec < 0x7fff %}{{ valdec }}{% else %}{{ valdec - 0x10000 }}{% endif %}
Input is #fffd
Decimal input is 65533
Adjusted for sign: -3
I tried this:
value_template: >
{%set outtempplus = value|replace('#','')|int(base=16,default=0)/100 %}
{%set outtempminus = value|replace('#','')|(65535 - int(base=16,default=0))/-100 %}
{{ outtempplus if outtempplus < 100 else outtempminus }}
…but it won’t work
…and I tried this:
value_template: >
{%set outtempdec = int(value[1:],base=16,default=0) %}
{% if outtempdec > 100 %}{{ outtempdec / 100 }}{% else %}{{ (65535 - outtempdec) / -100 }}{% endif %}
…and I get “NaN”
koying
(Chris B)
December 10, 2022, 12:06pm
5
Please show your full code.
What is the value of value
Your code is likely wrong but it gives me 655.33
for a value of "#fffd"
mqtt
sensor
- name: "Heizung Aussentemperaturfühler"
unique_id: "heatronic_aussen"
value_template: >
unit_of_measurement: "°C"
state_topic: "home/heizung/aussen"
state_class: "measurement"
Value is the temperaturemeasurement of my heating.
#0000 is 0,00 °C
#2710 is 100,00 °C
#F82f is -20,00 °C
every hexadecimal digit is 0,01 °C
koying
(Chris B)
December 10, 2022, 1:28pm
7
This works for me
value_template: >
{% if outtempdec < 0x7fff %}{{ outtempdec / 100 }}{% else %}{{ (outtempdec - 0xffff) / 100 }}{% endif %}
many thanks
why do i have to use hexadecimal valuses für arithmetic operations when i have a decimal value
