Hi everyone, I’m trying to take an RPM value from a server and turn it into a percentage. I have the RPM feeding into a Home Assistant sensor I just need to convert it.
So 0 RPM should be 0% and 20500RPM should be 100% and I can’t figure out how to write a template for this.
I’m really bad at math so I’m hoping someone can help me out here.
Replace sensor.fan_rpm with your fan rpm sensor entity_id in both templates.
It looks more complicated than it is.
As you have no offset the calculation is simply:
% = 100 * RPM / 20500
Which can be simplified to:
% = RPM / 205
The rest of the template is converting the state string to a number with|float, rounding it to a whole number with |round(0) and limiting the value to the range 0 to 100 in case your fan rpm ever slightly exceeds 20500, ([0,value,100]|sort)[1]
