Hey there,
thought I could share this.
The following sensor template solves two tasks:
- Derive a timestamp from a given number of seconds (assuming they point in the past)
- Ignore small changes from update to update (so the sensor in Home Assistant doesn’t see a state change regularly)
(In my example a microcontroller publishes its uptime via MQTT - however as it doesn’t know the absolute time, it will publish its uptime in seconds since startup.)
# "sensor.uptime" holds the number of seconds
template:
- sensor:
- name: uptime_since
unique_id: uniqueid__uptime_since
state: >
{% if is_state("sensor.uptime", "unavailable") %}
"unavailable"
{% else %}
{% set new_timestamp_s = as_timestamp(now() - timedelta(seconds=(states('sensor.uptime') | int()))) | round(0) %}
{% if is_state("sensor.uptime_since", "unknown") or is_state("sensor.uptime_since", "unavailable") %}
{{ new_timestamp_s | timestamp_local() }}
{% else %}
{% set current_timestamp_s = as_timestamp(states('sensor.uptime_since')) | round(0) %}
{% set difference_s = (current_timestamp_s - new_timestamp_s) | abs %}
{% if difference_s > 60 %}
{% else %}
{{ states('sensor.uptime_since') }}
{% endif %}
{% endif %}
{% endif %}
device_class: timestamp
icon: mdi:calendar-clock
Hope this is helpful. Feel free to ask questions or suggest improvements! I’m sure this can be reduced in length?
Cheers
