rcruikshank
(Robert Cruikshank)
July 21, 2020, 10:36pm
1
I have built the superhouse.tv Air Quality Sensor which produces the following MQTT output:
2c703
AE1P0 = 5
AE2P5 = 8
AE10P0 = 9
PPD0P3 = 1131
PPD0P5 = 293
PPD1P0 = 48
PPD2P5 = 4
PPD5P0 = 2
PPD10P0 = 2
SENSOR = {"PMS5003":{"CF1":5,"CF1":8,"CF1":9,"PM1":5,"PM2.5":8,"PM10":9,"PB0.3":1131,"PB0.5":1131,"PB1":48,"PB2.5":4,"PB5":2,"PB10":2}}
I have the following in configuration.yaml to extract the data:
# AQS
- platform: mqtt
unique_id: AE1P0
state_topic: "tele/12c703/AE1P0"
qos: 1
- platform: mqtt
unique_id: AE2P5
state_topic: "tele/12c703/AE2P5"
qos: 1
- platform: mqtt
unique_id: AE10P0
state_topic: "tele/12c703/AE10P0"
qos: 1
- platform: mqtt
unique_id: PPD0P3
state_topic: "tele/12c703/PPD0P3"
qos: 1
- platform: mqtt
unique_id: PPD0P5
state_topic: "tele/12c703/PPD0P5"
qos: 1
- platform: mqtt
unique_id: PPD1P0
state_topic: "tele/12c703/PPD1P0"
qos: 1
- platform: mqtt
unique_id: PPD2P5
state_topic: "tele/12c703/PPD2P5"
qos: 1
- platform: mqtt
unique_id: PPD5P0
state_topic: "tele/12c703/PPD5P0"
qos: 1
- platform: mqtt
unique_id: PPD10P0
state_topic: "tele/12c703/PPD10P0"
qos: 1
Which presents the following in Lovelace:
However this data is of type string and does not present correctly in a history graph:
So I tried to extract the data with the following:
- platform: mqtt
state_topic: "tele/12c703/SENSOR"
value_template: "{{ value_json.PMS5003.PM1 | int }}"
json_attributes_topic: "tele/12c703/SENSOR"
json_attributes_template: "{{ value_json.PMS5003 | tojson }}"
- platform: mqtt
value_template: "{{ value_json.PMS5003.PM2.5 | int }}"
- platform: mqtt
value_template: "{{ value_json.PMS5003.PM10 | int }}"
- platform: mqtt
value_template: "{{ value_json.PMS5003.PB0.3 | int }}"
- platform: mqtt
value_template: "{{ value_json.PMS5003.PB0.5 | int }}"
- platform: mqtt
value_template: "{{ value_json.PMS5003.PB1 | int }}"
- platform: mqtt
value_template: "{{ value_json.PMS5003.PB2.5 | int }}"
- platform: mqtt
value_template: "{{ value_json.PMS5003.PB5 | int }}"
- platform: mqtt
value_template: "{{ value_json.PMS5003.PB10 | int }}"
However I’m no java programmer and the period in some of the MQTT variable names causes me trouble. For example the period before the 5 in this value_json.PMS5003.PB2.5 makes PB2.5 unknown. Also I’m not sure the int command in the value_template is creating a variable of type integer properly as I still see a colour graph rather than line graph when I plot these new values in Lovelace.
What is the best way to extract this data and present as integers? Should I pass the MQTT messages to NodeRed and write a function that passes them back as integers in a new MQTT message?
Rob
tjntomas
(Tomas Jansson)
July 21, 2020, 11:40pm
2
Try using bracket notation instead for any key that contains a period:
value_template: "{{ value_json.PMS5003['PB2.5'] | int }}"
or
value_template: "{{ value_json['PMS5003']['PB2.5'] | int }}"
rcruikshank
(Robert Cruikshank)
July 22, 2020, 6:42am
4
No, doesn’t seem to work.
- platform: mqtt
value_template: "{{ value_json[PMS5003][PB0.3] | int }}"
- platform: mqtt
value_template: "{{ value_json[PMS5003][PB0.5] | int }}"
- platform: mqtt
Rob
tjntomas
(Tomas Jansson)
July 22, 2020, 8:07am
6
You forgot to enlose the keys in brackets in single qoutes:
value_template: "{{ value_json.['PMS5003']['PB0.5'] | int }}"
Troon
(Troon)
July 22, 2020, 8:49am
7
There’s a dot (period) that shouldn’t be there. Use:
value_template: "{{ value_json['PMS5003']['PB0.5'] | int }}"
tjntomas
(Tomas Jansson)
July 22, 2020, 9:37am
8
Thanks, I missed that while editing Robert’s reply.
rcruikshank
(Robert Cruikshank)
July 22, 2020, 1:56pm
9
Fantastic, that worked and the unit_of_measurement created the line graph.
877dev
(877dev)
September 20, 2024, 5:51pm
10
I came across this post a little late! But having the same issue it was most helpful, here is my mqtt.yaml
entry for anyone else who finds it:
I’m not sure what the CF value stands for still…
### SUPERHOUSE AQS SENSOR (LOUNGE) ###
# https://www.superhouse.tv/38-diy-air-quality-sensor-part-1-basic-model/
#CF
- name: "Lounge AQS CF1"
state_topic: "house/lounge/pms5003/edbbe9/SENSOR"
value_template: "{{ value_json['PMS5003']['CF1'] | int }}"
json_attributes_topic: "house/lounge/pms5003/edbbe9/SENSOR"
unit_of_measurement: ""
- name: "Lounge AQS CF2.5"
value_template: "{{ value_json['PMS5003']['CF2.5'] | int }}"
- name: "Lounge AQS CF10"
value_template: "{{ value_json['PMS5003']['CF10'] | int }}"
# The “PMx” values are micrograms per cubic meter.
- name: "Lounge AQS PM1"
value_template: "{{ value_json['PMS5003']['PM1'] | int }}"
unit_of_measurement: "ug/m3"
- name: "Lounge AQS PM2.5"
value_template: "{{ value_json['PMS5003']['PM2.5'] | int }}"
- name: "Lounge AQS PM10"
value_template: "{{ value_json['PMS5003']['PM10'] | int }}"
# The “PBx” values are particles per deciliter.
- name: "Lounge AQS PB0.3"
value_template: "{{ value_json['PMS5003']['PB0.3'] | int }}"
unit_of_measurement: "ppd"
- name: "Lounge AQS PB0.5"
- name: "Lounge AQS PB1"
value_template: "{{ value_json['PMS5003']['PB1'] | int }}"
- name: "Lounge AQS PB2.5"
- name: "Lounge AQS PB5"
value_template: "{{ value_json['PMS5003']['PB5'] | int }}"
- name: "Lounge AQS PB10"
value_template: "{{ value_json['PMS5003']['PB10'] | int }}"
# UK Air Quality Index
- name: "Lounge AQS UKAQI"
value_template: "{{ value_json['PMS5003']['UKAQI'] | int }}"
rcruikshank
(Robert Cruikshank)
September 20, 2024, 7:54pm
11
This is what chatgpt says
In air quality measurement, CF stands for Correction Factor . It is used to adjust raw data readings from particle sensors to improve accuracy. Some particle sensors provide readings that are labeled with a “CF” to indicate that the values have been corrected or adjusted based on specific environmental conditions or sensor calibration.
For example, CF=1 may refer to factory calibration for certain standard particles, while other CF values might be used to adjust the sensor readings for different types of particulate matter (PM) or environmental factors. This helps ensure that the sensor’s readings align more closely with actual air quality levels.
