I have a water level sensor successfully sending me a signal as a voltage. Its between 2.32v (empty) and 3.46v (full).
My question is: How to i convert that to a percentage?
Use the calibrate linear filter:
https://esphome.io/components/sensor/index.html#calibrate-linear
filters:
- calibrate_linear:
# Map 0.0 (from sensor) to 0.0 (true value)
- 2.32 -> 0.0
- 3.46 -> 100
thank you kind sir.
interesting. it’s sending back negative outputs.
[15:34:51][D][sensor:127]: 'Homestead Reserve Watertank Level': Sending state -111.31579 V with 0 decimals of accuracy
[15:35:01][D][sensor:127]: 'Homestead Reserve Watertank Level': Sending state -111.31579 V with 0 decimals of accuracy
removing all filters has shown another issue. looks like my sensor is faulty.
the issue was i did not have the attenuation set as it needs to be to ‘auto’ on the ESP32 device.
- platform: adc
pin: A4
name: "reserve tank water level"
update_interval: 15s
attenuation: auto
filters:
- median:
window_size: 15
send_every: 15
send_first_at: 15
