Convert your android Phone to Fake Chromecast and convert mediaplayer
Hello guys, after to read GitHub - skalavala/Multi-Room-Audio-Centralized-Audio-for-Home: 🎵 This Github Repository provides details on setting up a centralized audio system for your home using nothing but Raspberry Pi's and Old Speakers. @skalavala
i tried to find a cheaper solution, for create a multiroom áudio.
So i find the app android called “castreceiver” you can download it on playstore.
This is the code i use, many thanks a friend @Bob_NL
I want share that for all the people, who wants multiroom player with some old android phones or tablets.
PS: I use hass.io with modipy player and it Works.
Automation.yaml
#VOLUME RADIO
     - alias: Controla o Volume do CastReceiver
      platform: state
      entity_id: input_number.volume_radio
      service: mqtt.publish
      data_template:
        topic: 'zanzito/rodolfo/notification'
        payload_template: '{{states.input_number.volume_radio.state | int}}'
 input_select.yaml
estacoes_de_radio:
  name: 'Seleciona a estacao de Radio:'
  options:
    - Orbital
    - Oxigenio
zona_onde_toca:
  name: 'Seleciona a zona onde toca:'
  options:
    - Sala
    - Hall de entrada
  initial: Sala
  icon: mdi:speaker-wireless
 scripts.yaml
radio:
  alias: Play Radio on Chromecast Audio
  sequence:
    - service: media_player.volume_set
        entity_id: media_player.NAME_OF_YOUR_PLAYER
       volume_level: '0.35'
         volume_level: '0.20'
    -  service: media_player.play_media
       data_template:
         entity_id: >
           {%- if is_state('input_select.zona_onde_toca', 'Hall') -%}
           {%- elif is_state('input_select.zona_onde_toca', 'Sala') -%}
           {%- endif -%}
         media_content_id: >
            {%- if is_state('input_select.estacoes_de_radio', 'Orbital') -%}
               http://stream.radio.com.pt/ROLI-ENC-401
            {%- elif is_state('input_select.estacoes_de_radio', 'Oxigenio') -%}
               http://stream.radio.com.pt/ROLI-ENC-498
            {%- endif -%}
         media_content_type: 'audio/mp3'
customize.yaml
script.radio:
  friendly_name: Play
  icon: mdi:play
groups.yaml
    radio:
  entities:
    - input_select.estacoes_de_radio
    - input_select.zona_onde_toca
    - script.radio
    - input_number.volume_radio
   - media_player.NAME_OF_YOUR_PLAYER
Hi, thank you for sharing your project!
I installed this castreceiver and successfully pair it as chromecast on Hass.io and after changing my radio script I can make the streams play!
But I ran into some issues, the radio volume bar doesn’t change the sound and I can not stop the stream/radio from Hass I have to stop it manually on the device, have you experience this issues aswell?
hello friend how are you.
yes… there a issue with castreceiver.
as castreceiver not is a player of home assistant. we need to do a trick,
we need install tasker on the same phone where you installed castreceiver and make this:
first modify your code:
  • alias: Controla o Volume do CastReceiver
    platform: state
    data_template:
    topic: ‘zanzito/rodolfo/notification’
    payload_template: ‘{{states.input_number.volume_radio.state | int}}’
if you not use ZANZITO notifier, and you use pushbullet, telegrama or other modify for you.
the secret is … you need receiver one notification with the value of input_number.volume
after these apps:
tasker :https://drive.google.com/file/d/0Bx5iCI7ZrD0dZ3NTNHd1Tm5uNHM/view?usp=sharing
plugin autonotifier: https://drive.google.com/open?id=0Bx5iCI7ZrD0dcW02cy1VdkQ4MTQ
es explorer: https://play.google.com/store/apps/details?id=com.estrongs.android.pop&hl=pt_PT
after when you installed All.
OPEN es explorer and search the folder “tasker” click it
and follow the way tasker/configs/user/
and past inside folder “user” this: https://drive.google.com/file/d/12dDzFkxbjDJiWRjd180AGwLr1EAX5Bd9/view?usp=sharing
after that close the app es explorer and open
the app tasker
after open app tasker:
click on right top on PREFERENCES
and TAB “ui” BEGINNER MODE" put not check other words DESELECT that.
click back
and click again on righ top
now not click on the PREFERENCE but click on “DATA”
after RESTORE
after USER LOCAL BACKUP
and restore the file “backup”
after go back
and all the configurations are ok
now when you move the slider of volume…
the HA send you one notify…
your phone receive the notify “1” 2 3 or other,
and tasker adjust volume your phone :wink:
Thank you!!
And for stopping the media do you have any workaround?
Is modipy being used for the radio?
for stopping you can use
radio_pause:
alias: Parar o rádio na zona seleccionada
sequence:
- service: media_player.media_pause
data_template:
entity_id: >
{%- if is_state(‘input_select.zona_onde_toca’, ‘Cozinha’) -%}
media_player.Cozinha
{%- elif is_state(‘input_select.zona_onde_toca’, ‘Sala’) -%}
media_player.Sala
{%- endif -%}
Thanks, got it working!
just struggling with the volume since the tablet I am using isn’t compatible with Zanzito, Pushbullet or Telegram -.-
i dont understand.
Can not you install the telegram or other on the tablet?
Hi, everyone
Sice home assistant core at version 2022.8.X the divice is not suported in home assistant. Enyone are use CAST RECEIVER with this version?
Thakns
