Converting a MAX! Cube to CUL/CUN to use with Home Assistant
The only hassio add-on I could find for HomeGear appeared to be for Raspberry Pi - but I think its no longer maintained.
I use Hassio in a VM so that was no good for me anyway.
If you are using RPi I guess it should work OK though : Homegear Add-on for Hassio
