i could need some help with this issue, i have.
I have a sensor that gives a string “14:00:00”.
How can i convert this value, to a timestamp, so i can use it in an automation as time
the sensor is created and working, but the problem is, i need a decive_class “timestamp”, because i can’t use a normal device in an time automation (that only wants timestamp devices)
How can i convert this value to a timestamp?
I donot understand what is the issue… the code above goes to timestamp.
Add device_class = timestamp ?
I just picked random sensor with me
- name: teststamp
state: "{{ as_timestamp(state_attr('automation.testing','last_triggered')) | timestamp_local }}"
device_class: timestamp
this works fine, the problem must have been in the custom timestamp
thanks!
