Hey, i have found some cool project to use an robotic mawer, but the code is written in Arduino, but i want to use ESPHome, since i use the ESP also for other stuff
here is the sketch below, i think only the http webserver is relevant? Once the webserver is ready, i need to upload a .bin file
Who can help me?
source of project:: Mähspitzel - Wi-Fi für Robomow ( in german)
* Board: "LOLIN D32 PRO"
* Upload Speed: "921600"
* Flash Frequency: "80MHz"
* Partition Scheme: "Minimal SPIFFS (Large APPS with OTA)"
* Core Debug Level: "Keine"
* PSRAM: "Enabled"
* Port
#define LOGIN_CREDENTIALS_LENGTH_MAX 32
/* Anfang Konfigurationsabschnitt */
const char WLAN_local_SSID[32] = "meineSSID"; // Geben Sie Ihre bestehende lokale WLAN SSID ein
const char WLAN_local_password[32] = "meinKennwort"; // Geben Sie Ihr bestehendes lokales WLAN-Passwort ein.
const char http_username[LOGIN_CREDENTIALS_LENGTH_MAX] = "Mspitzel"; // HTTP Benutzername, maximum von 31 Zeichen
const char http_password[LOGIN_CREDENTIALS_LENGTH_MAX] = "Mspitzel007"; // HTTP Kennwort, maximum von 31 Zeichen
/* Ende Konfigurationsabschnitt */
#include <WiFi.h>
#include <WebServer.h>
#include <HTTPUpdate.h>
#include <HTTPClient.h>
#include <WiFiClient.h>
#include <EEPROM.h>
const char* host = "mspitzel";
const char* def_ssid = "Mspitzel";
const char* def_pass = "Mspitzel007";
int eeprom_allocated_mem = 4096;
int eeprom_login_credentials_base=64;
const char* serverIndex = "<form method='POST' action='/update' enctype='multipart/form-data'><input type='file' name='update'><input type='submit' value='Update'></form>";
WebServer httpServer(8080);
HTTPUpdate httpUpdater;
WiFiClient WLAN_Client;
IPAddress local_ip;
void setup(void) {
/* Serielle Schnittstelle initialisieren */
Serial.begin(115200);
Serial.println();
/* Clear EEPROM */
Serial.print("Lösche EEPROM-Inhalt...");
EEPROM.begin(eeprom_allocated_mem);
#define EVENTLOG_ADR 1024
//for (int i = 0; i < EVENTLOG_ADR; ++i) { // Einsatzprotokoll nicht löschen
for (int i = 0; i < eeprom_allocated_mem; ++i) {
EEPROM.write(i, 0);
Serial.println("erledigt");
/* Speicher http Benutzername / Kennwort in EEPROM */
EEPROM.put(eeprom_login_credentials_base, http_username);
EEPROM.put(eeprom_login_credentials_base + LOGIN_CREDENTIALS_LENGTH_MAX, http_password);
Serial.println("Einrichten des Firmware-Uploads...");
if (!Local_WLAN_Connect()) {
/* Standardverhalten - spawn access point */
WiFi.mode(WIFI_AP);
WiFi.setHostname(host);
WiFi.softAP(def_ssid, def_pass);
Serial.printf("Erstellter WLAN-Zugangspunkt mit WLAN SSID %s\n",def_ssid);
/* lokale IP */
local_ip = WiFi.softAPIP();
Serial.printf("\n>>> Verbindung zum WiFi-Netzwerk \"%s\" mit Kennwort \"%s\"\n\n",def_ssid, def_pass);
EEPROM.commit();
EEPROM.end();
httpServer.on("/", HTTP_GET, []() {
httpServer.sendHeader("Connection", "close");
httpServer.send(200, "text/html", serverIndex);
httpServer.on("/update", HTTP_POST, []() {
httpServer.send(200, "text/plain", (Update.hasError()) ? "Fehler" : "In Ordnung");
delay(1000);
ESP.restart();
HTTPUpload& upload = httpServer.upload();
if (upload.status == UPLOAD_FILE_START) {
Serial.setDebugOutput(true);
Serial.printf("Update: %s\n", upload.filename.c_str());
if (!Update.begin()) {
Update.printError(Serial);
} else if (upload.status == UPLOAD_FILE_WRITE) {
if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
} else if (upload.status == UPLOAD_FILE_END) {
if (Update.end(true)) { //true, um die Größe an den aktuellen Fortschritt anzupassen
Serial.printf("Update erfolgreich: %u\nNeustart...\n", upload.totalSize);
} else {
Serial.setDebugOutput(false);
yield();
httpServer.begin();
Serial.println("HTTP Server gestartet");
return;
void loop(void){
httpServer.handleClient();
boolean Local_WLAN_Connect() {
/* Versuch lokales WLAN zu benutzen mit den angegebenen Zugangsdaten */
if ( strlen(WLAN_local_SSID) && strlen(WLAN_local_password)) {
/* Wifi client mode */
WiFi.mode(WIFI_STA);
/* mit bestehendem WLAN verbinde */
Serial.printf("Verbindung mit lokaler WLAN-SSID %s",WLAN_local_SSID);
WiFi.begin(WLAN_local_SSID, WLAN_local_password);
/* Warten, bis die Verbindung erfolgreich ist */
for (int i = 0; i < 20; i++) { //timeout [s]
delay(1000);
int connectionStatus = WiFi.status();
switch(connectionStatus) {
case WL_CONNECTED:
Serial.println("...verbunden");
local_ip = WiFi.localIP();
/* WiFi-Zugangsdaten in EEPROM speichern */
EEPROM.put(0,WLAN_local_SSID);
EEPROM.put(32,WLAN_local_password);
return true; // WLAN-Verbindung erfolgreich
default:
Serial.print(".");
Serial.println("...nicht in der Lage, eine Verbindung herzustellen"); // zum Standardverhalten zurückkehren
return false;
