Last year i managed to create two custom components for logging “serial” data from my heatpump device.
I tried to convert those into external components without any luck for days now…
I created the correct file/folder structure on my github, and i created new .yaml “ctc2esp-ext.yaml” for external component instead of custom component “ctc2esp.yaml”
While compailing i do get following error:
ctc2esp.yaml: In lambda function:
ctc2esp.yaml:58:35: error: expected type-specifier before ‘DP’
ctc2esp.yaml:65:42: error: could not convert ‘{, , , , , }’ from ‘’ to ‘std::vectoresphome::binary_sensor::BinarySensor*’
ctc2esp.yaml:78:35: error: expected type-specifier before ‘HP’
ctc2esp.yaml:85:53: error: could not convert ‘{, , , , , }’ from ‘’ to ‘std::vectoresphome::sensor::Sensor*’
Archiving .pioenvs\ctc2esp\lib8a0\libAsyncTCP-esphome.a
Compiling .pioenvs\ctc2esp\lib524\WiFi\WiFiScan.cpp.o
Compiling .pioenvs\ctc2esp\lib524\WiFi\WiFiServer.cpp.o
Compiling .pioenvs\ctc2esp\lib524\WiFi\WiFiUdp.cpp.o
*** [.pioenvs\ctc2esp\src\main.cpp.o] Error 1
Could some one point me into right direction ? Or a step by step guide for conversion of custom components into external components?
Github : mercix/CTC2ESP
Best regards
/Mercix
