Converting psuedo code logic to a script in HASS
i want to translate the following code to be run in a HASS script but i have no idea how to start with this:
currentIndex = last value published by topic /home/tempsensor
mode = input_select.ac1_auto_mode
minIndex = input_number.ac1_auto_min_index
maxIndex =  input_number.ac1_auto_max_index
if (mode == "Cool")
	if (currentIndex > minIndex)
		run remote.send_command -> { "entity_id":"remote.ac_1", "command":"cold" }
else if (mode == "Warm")
	if (currentIndex < maxIndex)
		run remote.send_command -> { "entity_id":"remote.ac_1", "command":"warm" }
any help would be appreciated
Unfortunately, this is not easily done in a single script.
You’ll need an MQTT Sensor to get the last value of /home/tempsensor
And since scripts can’t do “else if” or “else”, you’ll need one script to start it off, and additional scripts with conditions to achieve these goals.
A far easier way to accomplish this is with a python_script or with AppDaemon. For either of those, you’ll need to learn a little python. NodeRed is another popular option (that I don’t care for myself). So you may want to look into that as well.
i’m on it - thx. going with the python approach.
just a small related question - trying to use:
sourceSensor = hass.states.get('input_select.ac1_auto_source_sensor')
logger.info('sourceSensor=%s', sourceSensor)
in a python script, but the output is not the state:
sourceSensor=<state input_select.ac1_auto_source_sensor=Sensor 1; options=['Sensor 1'], friendly_name=AC1 Source Sensor @ 2019-08-06T22:30:02.057967+03:00>
how do i get the selected field’s text from the input select?
I would assume sourceSensor is a state object, so try sourceSensor.state.
working - thx :slight_smile:
