Converting to ESPHome - Code Optimization Needed
I have a self-made temperature/humidty sensor (Si7021) with an display (SH1106) attached to it in a small case.
Because I want to get rit of MQTT, I have “re-written” the code with ESPHome.
However, before the “code converversion” I had a temperature offset of -1.3 degree in comparision to my reference sensor and after it’s -5.2 degree.
Which leads me to the conclusion that the ESPHome-Code needs optimization.
esphome:
  platform: ESP8266
  board: nodemcuv2
api:
wifi:
  ssid: 'myWIFI'
  password: 'mySecret'
  manual_ip:
    static_ip: 192.168.1.41
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  power_save_mode: high
# Enable logging
logger:
  level: none
i2c:
ota:
spi:
  clk_pin: 14
  mosi_pin: 13
  - platform: wifi_signal
    name: "SH1106 Si7021 - RSSI"
    filters:
        - delta: 2.0
  - platform: htu21d
    temperature:
      filters:
        - delta: 0.4
        - offset: -5.2
      name: "SH1106 Si7021 - Temperature"
      unit_of_measurement: "°C"
    humidity:
      filters:
        - delta: 1.2
        - offset: 6.0
      name: "SH1106 Si7021 - Humidity"
      accuracy_decimals: 1
      unit_of_measurement: "%"
    update_interval: 60s
time:
  - platform: homeassistant
font:
  - file: "sh1106_si7021_dependencies/arial.ttf"
  - file: "sh1106_si7021_dependencies/Logisoso.ttf"
display:
  - platform: ssd1306_spi
    model: "SH1106 128x64"
    cs_pin: 15
    dc_pin: 0
    reset_pin: 2
    pages:
      - id: page1
        lambda: |-
          it.printf(15, 23, id(logisoso_42), "%.1f", id(temperature).state);
          it.line(0, 46, 127, 46);
          it.print(13, 48, id(arial_14), "Temperature (°C)");
      - id: page2
        lambda: |-
          it.printf(15, 23, id(logisoso_42), "%.1f", id(humidity).state);
          it.print(16, 48, id(arial_14), "Humidity (%)");
      - id: page3
        lambda: |-
          it.strftime(2, 5, id(logisoso_26), "%H:%M:%S", id(time_hass).now());
          it.strftime(27, 48, id(arial_14), "%d.%m.%Y", id(time_hass).now());
interval:
  - interval: 3s
    then:
      - display.page.show_next: my_display
      - component.update: my_display
Do you have any suggestion?
filters:
  - delta: 0.4
  - offset: -7.2
This bit as a semi-educated guess
I edited my first post to change the offset to “-5.2” to show that the temperature got 2 degree down by using power_save_mode: high.
