Converting Zwave sensor output (Philio) into actionable automation
I’ve got 4 nodes currently working fine in my Zwave setup and have recently added a 5th from Philio, their outdoor PIR sensor.
The node itself is detected fine, and it’s registered the following entities
Entities of this node
sensor.Philio Technology Corporation Unknown: type=0002, id=0050 SourceNodeId
binary_sensor.Philio Technology Corporation Unknown: type=0002, id=0050 Sensor
sensor.Philio Technology Corporation Unknown: type=0002, id=0050 Alarm Level
sensor.Philio Technology Corporation Unknown: type=0002, id=0050 Alarm Type
sensor.Philio Technology Corporation Unknown: type=0002, id=0050 Burglar
However I cannot work out which entity triggers on motion (they all seem to appear in the logs when I wave my hand in front of the sensor) and furthermore, what information they are sending home assistant.
Can someone advise what automation rule I would need to have this sensor turn on a couple of my zwave plugs?
Many thanks
Look at the sensors under the HA web page and note which ones change when you wave. Typically it would be the Burglar or Alarm level that you want to focus on.
