coolMasterNet integration problem
Hi. I can’t integrated coolmasternet to home assistant. Home assistan working with raspberry pi4. (
CoolMasterNet - Home Assistant ) the link You can see how we should integrate CoolMasterNet with Home Assistant, but unfortunately in my case it is unsuccessful and I don’t know why. When I integrate it required host name. And I write this 192.168.90.33 IP address. This IP is coolmasternet’s IP. They both same network. And “this host not found” writing. I tried static IP and DHSP.
I made my CoolMaserNet online.
Please help me.
FOTO
IMG-20211005-014606 — ImgBB
What’s in the logs ? I get that I have cloud mode only and it means no local access… only with the app.
Trying to figure out how can I use it anyway with HA.
I did fix it.
I am getting the same error, when I am entering the ip of coolautomation device, it is saying unknown error, How did you fix this issue?
How did you fix this issue?I have the same issue
