Cooper RF9540 configuring for Instant Status?
I picked up a Cooper RF9540-N to try out and I am having some problems getting the Instant Status feature to work correctly (or at all).
  • When I press the physical switch to turn the light on, the status will update to show that the light is on, but the DIM level doesn’t update all the way.
  • When I press the physical switch to turn the light off, the status will register that it was at full brightness and started to DIM, but will not recognize that the switch is off.
In Home Assistant,
  • When the light is off and I press the switch in HA, it will show the Dimmer as starting to turn on.
  • When I press the switch in HA to turn the light off, it will update to the Dimmer as off…
I am running HASS.io 0.101 (HA version 0.67.1).
My z-wave controller is an Aeotec Z-Stick Gen 5.
This is what the switch looks like in OZWCP
There don’t appear to be any node config options for this dimmer (or neither HA nor OZWCP are showing them.)
