Coordinate multiple automations / simple choreography by priority
This coordinates multiple automations that are identified by their tag and priority.
It works in that way that automations with higher priority turn off automations with lower priority. When these automations finish they will turn back on automations with lower priority.
You can coordinate as many automations and priority levels you need.
This is usefull if you have multiple automations that affect the same entities and you do not want to put conditions everywhere distributed in your automations. The automations get more decoupled and do not need to know the states of each other.
Please rename your automations that you want to coordinate so that this automation can identify them. The name of all automations of a specific group must follow this pattern
[automation_name]tag:[automationtagname]:priority:[decimal_number].
For example basic_airquality_tag:airquality:priority:1 manual_fresh_airflow_tag:airquality:priority:2
above bpmn diagram shows an example where the automated night light is interrupted when the light ist set manually. ( created with https://bpmn.io/ )
You can extend more automations and priority levels later and create multiple coordination automations by using different tags.
updated: use of the new multiple selector option to ease setup :slight_smile: thank you for the 2022.4 release selector update :hearts:
Blueprint Code
Needs Home Assistant Core 2022.4 or higher
Click the badge to import this Blueprint:
Or import this Blueprint by using the forum topic URL:
blueprint:
  name: _Automation Coordination
  description: This Coordinates multiple automations that are identified by their tag and priority. It works in that way that automations with higher priority turn off automations with lower priority. When they finish all automations will be enabled again. You can coordinate as many automations and priority levels you need. Please rename your automations that you want to coordinate so that this automation can identify them. The name of all automations of a specific group must follow this pattern -automation_name tag:automationtagname:priority:decimal_number. For example basic_airquality_tag:airquality:priority:1 manual_fresh_airflow_tag:airquality:priority:2
  domain: automation
  input:
    automations:
      description: The name of the automations that are coordinated  must follow this pattern -automation_name tag:automationtagname:priority:decimal_number . Select all automations that will be coordinated e.g. basic_airquality, manual_fresh_airflow. You can also change or extend this after the blueprint automation is created.
      selector:
        entity:
          multiple: true
          domain: automation
  - platform: state
    entity_id: !input automations
condition: []
  - variables:
      priority: >
        {% set priority =
        trigger.to_state.attributes.friendly_name.split('priority:')[1]%}  {% if
        priority is not none %}
          {{ priority }}
        {% else %}
          false
        {% endif %}
      tag: >
        {% set tag =
        trigger.to_state.attributes.friendly_name.split('tag:')[1]%}  {% set tag
        = tag.split(':priority:')[0]%} {% if tag is not none %}
          {{ tag }}
        {% else %}
          false
        {% endif %}
  - service: group.set
      entities: !input automations
      object_id: priorityautomation_{{tag}}
  - choose:
      - conditions:
          - condition: template
            value_template: >
              {% if trigger.from_state and trigger.to_state.attributes.current
              == 1 %}
                true
              {% else %}
                false
              {% endif %}
        sequence:
          - repeat:
              count: >-
                {% set groupname = 'group.priorityautomation_'+tag %} {{
                expand([trigger,groupname]) | count }}
              sequence:
                  value_template: >-
                    {% set groupname = 'group.priorityautomation_'+tag %} {%-
                    set currentautomationpriority =
                    int(state_attr(expand([trigger,groupname])[int(repeat.index)-1].entity_id,'friendly_name').split('priority:')[1])-%}
                    {%- if currentautomationpriority < priority -%}{{true}}{%-
                    else-%}{{false}}{%- endif -%}
                - service: automation.turn_off
                    entity_id: >
      - conditions:
            value_template: >
              == 0 %}
                true
              {% else %}
                false
              {% endif %}
        sequence:
          - variables:
              priority_still_running: 0
          - repeat:
              count: >-
              sequence:
                  value_template: >-
                    {%- if currentautomationpriority >= priority -%} {%- elif
                    state_attr(expand([trigger,groupname])[int(repeat.index)-1].entity_id,'current')==1
                    -%} {{true}}{%- else-%}{{false}}{%- endif -%}
                - variables:
                    priority_still_running: 1
          - repeat:
              count: >-
              sequence:
                  value_template: >-
                    {%- if currentautomationpriority < priority and
                    priority_still_running == 0 -%}{{true}}{%-
                - service: automation.turn_on
                    entity_id: >
    default: []
mode: single
