Copy/link to ssl directory automation
I have gone through the trouble of compiling a neat little acme client for home assistant on the raspberry pi, I have fixed scripts to update them. However, it seems that I cannot update the ssl directory in automations, due to it being read-only. Now, because I do not want to restart Core for https in case of of other things being interrupted, I have resorted to nginx-proxy addion, but this only reads certificates in the /ssl directory.
How can I make either nginx addon read my automatically updated ssl certificates, or write to the /ssl directory?
Hello Xaesar,
I would think if you did the action with a script from the “Advanced SSH & Web Terminal” add-on and the samba add-on or using a
then you should have the access you need.
