I’m new to Home Assistant. I was using JeeDom previously, but I have just migrated to Home Assistant when JeedDom crashed once again after an update …
I was using jeedom to monitor my consumption of wood pellets in my boiler. For that, I’m using a ZWave Fibaro Wall Plug which measure the power consumption of the vaccum which bring the pellet to the boiler.
Each time the vaccum is triggered, I log a line which allow me to determine the quantity of pellet sucked in the boiler, and determine approximatly the overall consumption.
The log file is then sent to my nas where I can make my excel sheet review.
This was working fine in jeedom, and I would like to do the same in home assistant.
So what I have done :
- Zwave installed and configured
- Fibaro plug wall configured and monitored
- Configuration.yaml file updated to declare my own log file :
configuration.yaml
# Adding additional notifier file
notify:
- name: Log_Granule
platform: file
filename: /config/log_granule.log
timestamp: TRUE
- Automation created to trigger a notification in a dedicated log file :
Configuration of my automation
alias: Detection Aspiration
description: Detection Aspiration Granule
- platform: numeric_state
entity_id: sensor.metered_wall_plug_switch_power
for:
hours: 0
minutes: 0
seconds: 5
above: 500
condition: []
- service: notify.log_granule
message: Detection Aspiration
title: Title
mode: single
- NAS samba point declared and mounted (both for backup and shared folder).
Share Folder configuration
- backup on the NAS work perfectly well
And I’m stuck there. I don’t understand what to do to create an automated task which will copy my log file on the mount point I have declared.
I’m sure it’s not so difficult, but I’m a bit lost with all the different concept.
I have setup a workaround which work, but I don’t like it : I have configured a SSH Access to homeassistant, and I’m retrieving the file in the other way. I have writter a script in python which connect in sftp to homeassistant and retreive the file. But I would like to push it instead, and mainly, I would like to understant how to proceed
Other question : is there a way to define the file name of the backup ? Because it’s not really easy to read
01/10/2023 18:41 080f51ab.tar
01/10/2023 18:49 9bd03362.tar
02/10/2023 03:00 d62ba92b.tar
01/10/2023 18:46 dbed1896.tar
Thanks in advance !
