Copy to-do list items
I’m trying to copy shopping list from Mealie to Bring!, I have both on HA and created an automation which works fine when doing it from HomeAssistant, inserting in Mealist To-Do list will update Bring! list with the same item.
However, it doesn’t work when adding items directly from Mealie GUI, I’m assuming it doesn’t trigger the same event.
I’ve also tried to “get all” items, and save them into a response variable, the problem is… I don’t know how to use it to insert all items in the second list :slight_smile:
Any help will be greatly appreciated. Thank you!
Hi there! I was also trying to sync a bring list with my mealie list and stumbled on your post while searching for solutions.
In case you (or others) are still trying to do this, I documented my automation approach here:
Idk how you managed this wizardry but thank you so much!!
