I’ve been trying to trigger my garage door remote with these modules:
This is the raw code that I captured with the receiver:
310, -993, 312, -1038, 308, -1000, 306, -999, 309, -997, 311, -1038, 307, -1000, 305, -1007, 989, -360, 993, -362, 302, -1000, 302, -1000, 990, -368, 982, -373, 290, -1009, 279, -1068, 297, -1010, 299, -1009, 299, -1007, 301, -1007, 301, -1007, 301, -1009, 996, -364, 994, -360, 304
I am triggering it with this piece of yaml without any luck:
switch:
name: Raw Code Power Button
turn_on_action:
- remote_transmitter.transmit_raw:
code: [310, -993, 312, -1038, 308, -1000, 306, -999, 309, -997, 311, -1038, 307, -1000, 305, -1007, 989, -360, 993, -362, 302, -1000, 302, -1000, 990, -368, 982, -373, 290, -1009, 279, -1068, 297, -1010, 299, -1009, 299, -1007, 301, -1007, 301, -1007, 301, -1009, 996, -364, 994, -360, 304]
repeat:
times: 10
wait_time: 50ms
It’s worth noting that I am holding the transmitter less than a meter away from the garage door receiver, and for my other door it works fine.
This is the remote I am trying to copy:
There’s not much in the espHome logs but this:
17:10:31 [D] [switch:012]
'Raw Code Power Button' Turning ON.
17:10:31 [D] [remote_transmitter:075]
Sending remote code...
17:10:31 [W] [component:237]
Component web_server took a long time for an operation (773 ms).
17:10:31 [W] [component:238]
Components should block for at most 30 ms.
If I capture the signal emitted by the esp controlled module these are the logs:
17:20:53 [I] [remote.raw:028]
Received Raw: 326, -966, 329, -1019, 327, -982, 320, -985, 325, -981, 326, -1022, 320, -989, 317, -997, 1002, -344, 1004, -353, 310, -993, 303, -1000, 989, -370, 977, -377, 286, -1013, 278, -1069, 296, -1014, 291, -1016, 291, -1016, 293, -1015, 292,
17:20:53 [I] [remote.raw:041]
-1013, 300, -1011, 987, -375, 982, -373, 294
Received Raw: 318, -981, 325, -1026, 317, -990, 313, -993, 317, -990, 317, -1031, 313, -994, 311, -1001, 993, -358, 991, -364, 299, -1007, 296, -1002, 987, -373, 975, -380, 282, -1017, 269, -1081, 285, -1019, 290, -1019, 288, -1017, 292, -1017, 290,
-1017, 291, -1019, 984, -378, 984, -370, 293
Received Raw: 318, -985, 320, -1031, 313, -994, 312, -993, 314, -992, 316, -1034, 309, -997, 308, -1005, 991, -361, 989, -364, 300, -1002, 299, -1004, 983, -379, 971, -381, 279, -1019, 270, -1078, 287, -1020, 290, -1018, 288, -1019, 292, -1016, 291,
-1020, 287, -1019, 985, -377, 979, -376, 287
Received Raw: 318, -984, 321, -1029, 313, -998, 310, -993, 316, -991, 315, -1034, 309, -996, 310, -1004, 988, -362, 990, -366, 297, -1005, 297, -1006, 984, -376, 971, -383, 279, -1018, 274, -1075, 286, -1020, 287, -1021, 289, -1017, 290, -1019, 290,
17:20:54 [I] [remote.raw:041]
-1019, 293, -1016, 984, -376, 980, -375, 289
17:20:54 [I] [remote.raw:028]
Received Raw: 323, -982, 320, -1030, 314, -993, 312, -994, 313, -993, 321, -1027, 316, -994, 307, -1005, 988, -360, 990, -366, 300, -1002, 298, -1004, 983, -378, 972, -384, 279, -1017, 270, -1078, 287, -1020, 288, -1021, 286, -1019, 290, -1019, 290,
-1018, 290, -1019, 983, -380, 977, -377, 286
Received Raw: 319, -984, 320, -1029, 318, -991, 315, -991, 315, -991, 318, -1031, 312, -995, 310, -1002, 994, -355, 996, -360, 299, -1004, 297, -1005, 985, -375, 975, -379, 284, -1016, 272, -1076, 287, -1020, 288, -1020, 288, -1019, 288, -1020, 293,
-1013, 294, -1017, 983, -378, 978, -377, 287
Received Raw: 312, -986, 321, -1030, 315, -993, 310, -995, 314, -992, 317, -1033, 310, -997, 308, -1005, 991, -358, 991, -364, 298, -1004, 298, -1004, 984, -377, 972, -383, 279, -1019, 269, -1079, 285, -1021, 289, -1020, 287, -1018, 292, -1017, 290,
-1017, 291, -1023, 982, -375, 982, -373, 293
Received Raw: 314, -985, 321, -1029, 315, -993, 313, -991, 315, -992, 316, -1036, 309, -998, 306, -1005, 991, -357, 991, -366, 298, -1003, 298, -1004, 985, -376, 973, -383, 277, -1020, 270, -1077, 286, -1022, 289, -1018, 289, -1017, 292, -1017, 289,
-1018, 291, -1019, 984, -377, 979, -378, 287
Received Raw: 316, -986, 320, -1033, 311, -995, 312, -992, 321, -984, 323, -1026, 311, -999, 307, -1004, 990, -362, 990, -363, 304, -998, 302, -1000, 985, -375, 975, -381, 280, -1020, 269, -1078, 286, -1025, 284, -1020, 286, -1020, 289, -1021, 286,
-1021, 287, -1022, 981, -382, 977, -377, 285
This is what I get when I press the button on the remote:
17:24:05 [I] [remote.raw:028]
Received Raw: 316, -987, 316, -1030, 317, -990, 314, -992, 317, -990, 316, -1031, 316, -991, 315, -993, 999, -356, 998, -353, 311, -1126, 2015, -508, 994, -357, 306, -998, 309, -1038, 306, -1002, 305, -999, 310, -998, 310, -998, 311, -996, 311, -1000,
17:24:05 [I] [remote.raw:041]
681, -678, 1001, -357, 307
Received Raw: 316, -987, 318, -1029, 317, -989, 315, -992, 318, -989, 316, -1031, 315, -991, 316, -992, 999, -355, 1000, -352, 311, -1017, 286, -991, 657, -698, 993, -358, 306, -1000, 299, -1130, 1532, -997, 311, -996, 311, -997, 311, -996, 313, -999,
1002, -358, 1001, -356, 307
Received Raw: 320, -985, 320, -1026, 320, -988, 314, -992, 316, -991, 317, -1032, 315, -991, 315, -994, 998, -353, 1001, -352, 311, -994, 307, -993, 1000, -352, 1000, -353, 310, -998, 307, -1040, 303, -1004, 305, -1000, 309, -999, 307, -999, 311, -997,
302, -1009, 1002, -359, 999, -357, 306
Received Raw: 316, -988, 316, -1030, 317, -989, 315, -992, 318, -989, 318, -1030, 315, -991, 318, -990, 1000, -353, 1000, -352, 311, -1073, 2213, -361, 997, -361, 303, -1000, 720, -623, 310, -1104, 1511, -997, 312, -995, 312, -996, 312, -999, 1003, -357,
1000, -356, 308
Received Raw: 316, -986, 318, -1029, 318, -990, 313, -993, 317, -990, 318, -1030, 315, -991, 316, -993, 999, -353, 1001, -352, 311, -994, 306, -994, 556, -799, 994, -359, 307, -995, 312, -1034, 311, -997, 295, -1014, 308, -998, 310, -997, 311, -997, 310,
-1001, 923, -440, 698, -656, 306
Received Raw: 316, -988, 317, -1029, 317, -990, 314, -992, 318, -990, 317, -1031, 315, -991, 315, -993, 1000, -353, 1001, -351, 312, -993, 311, -991, 458, -895, 997, -354, 309, -997, 309, -1040, 305, -998, 311, -997, 310, -997, 310, -997, 312, -996, 314,
-997, 1003, -357, 1001, -355, 308
Received Raw: 316, -987, 317, -1029, 317, -990, 317, -989, 318, -989, 318, -1030, 315, -992, 315, -993, 1000, -351, 1002, -351, 313, -990, 314, -992, 995, -360, 859, -489, 309, -996, 310, -1038, 306, -999, 309, -998, 310, -998, 310, -997, 1619, -1000,
1003, -357, 1000, -356, 307
Received Raw: 315, -989, 315, -1031, 316, -991, 316, -990, 317, -990, 319, -1029, 315, -992, 315, -996, 998, -351, 1003, -350, 314, -993, 306, -993, 401, -1000, 446, -1012, 1462, -324, 357, -353, 313, -996, 311, -995, 313, -994, 314, -993, 314, -994,
314, -997, 1006, -354, 1003, -353, 310
Received Raw: 318, -987, 318, -1028, 318, -989, 317, -990, 320, -987, 320, -1028, 317, -989, 317, -992, 1000, -352, 1003, -351, 312, -992, 307, -994, 588, -767, 995, -357, 306, -997, 990, -358, 308, -998, 310, -998, 310, -996, 311, -997, 312, -995, 313,
-999, 1003, -358, 998, -358, 306
Do you have any ideas of what I might be doing wrong?
Thanks so much
